04-09-2011, 06:15 PM | #1 |
Fixed my glove box for less than 5 bucks.
The glove box for my truck came in a box of extra parts when I bought it. The plastic had already broken. I found some hinges at the hardware store that worked out really well.
I used the brass screws that came with the hinges and just screwed them into the plastic part of the glove box. The screws will have to be shortened to clear the dash. I used my bench grinder to do this. I only needed two hinges, it works just as new!!! It doesnt look so bad either. |
04-09-2011, 07:45 PM | #2 |
yeller
Re: Fixed my glove box for less than 5 bucks.
You should be able to get a used, but not broken, glovebox liner for 5 bux or even free at a local wrecking yard...and it would look/function just like it was supposed to.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-09-2011, 08:11 PM | #3 |
Getcha Pull
But then you don't have the bling-bling!
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
04-09-2011, 08:39 PM | #4 |
The One And Only !!!
But the bling-bling could have been toned down with a shot of black paint !
Brian76GMC, Good job if it works for you....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
04-09-2011, 09:21 PM | #5 |
I havent found another glovebox that isnt broke or half way to being broken. This was a simple solution for me and it wont break!!!!!!!
Bling? Like the 14x5 chrome air cleaner I just put on top of the crusty, oily, tired 350 under the hood?? hehe |
04-10-2011, 08:23 AM | #6 |
Dont listen to them, thats some FINE ENGINUITY going there.
2004 Silverado Crewcab (Dark Spiral Gray) |
04-10-2011, 07:40 PM | #7 |
I usually use a piece of leather in place of the plastic that the factory uses. It is flexable and doesn't crack.
04-11-2011, 09:37 AM | #8 |
Cool I was thinking about doing this so its good to know it worked for someone else. I think I am going to use a long piano type hinge that runs the length of the glove box though.
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
