04-11-2011, 10:03 AM | #1 |
Leaking bag help
I have a right front bag leaking on 72 mounted to plate and cup
i removed line from fill valve and placed valve core fitting to fill bag dipped the core in bucket of water no bubles next day its down removed bag and all line up to valve submerged it all in bucket added only 25 psi till bag was streched no leaks then reinstalled in truck only to find next day its down again. What is the best way to locate small leaks the whole setup under water didn't work ????
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 |
04-11-2011, 12:33 PM | #2 |
someday it will be done!
Re: Leaking bag help
I would suspect the fitting first.Are you installing them with tape?Sometimes the leaks are so small that they are easy to miss.I've had good luck spraying windex on the connections and watch it like a hawk for at least a minute.If it isn't that then it would have to be the bag and that would mean replacing.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
04-11-2011, 03:19 PM | #3 |
spray soapy water as mentioned
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 04-11-2011 at 03:20 PM. |
04-11-2011, 04:16 PM | #4 |
When the bags are installed & leaking down, what pressure are you filling them to? Use that same pressure for your testing.
04-11-2011, 04:35 PM | #5 |
is it possible that your exhaust valve leaks?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
04-11-2011, 05:30 PM | #6 |
as stated put one bag with swivel fitting 3" air line one valve core fitting in submerged tank for 5 min no bubbles but it was a lower pressure didn't want to over strech the bag in water tank? after removing just changed to new line for the corect length and leak is back
is there any dye that could safely show this leak as in aircondisioners??
04-11-2011, 06:11 PM | #7 | |
Diluted dish-water or Windex are the tools I've always seen used to isolate air leaks.
04-11-2011, 06:25 PM | #8 | |
We build allot of oil tanks and trailers with air brakes and all need to be leak tested, the best way I've found is as mentioned already with soapy water but I like to just put a little bit in the spray bottle and shake it up real good to make allot of suds in the spray bottle, so that when you spray it on you'r actually spraying on the suds. The suds will show a small leak allot better than just wet soapy water.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
04-11-2011, 06:17 PM | #9 |
Snoop, which is soapy water can find small leaks.
04-19-2011, 12:49 AM | #10 |
Problem solved?curious minds wanna know.
04-19-2011, 07:01 AM | #11 |
Yellow truck club
Better than dish soap is the kids bubble stuff. The new dish soap seams to be loosing it bubble ablility but the kids stuff is made just to make bubbles.....
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
04-19-2011, 10:05 AM | #12 |
This is what I used @ work to find air leaks. They looked @ me funny when I was buying 3 gallons of the stuff....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-19-2011 at 10:06 AM. |
04-19-2011, 12:51 PM | #13 |
aparently each time i bolt bag with plate back in it must be slight twist on line to cause leak the last install no leaks so thanks for all the sugestions just one of little gremlins to keep agrevating me i hope down the road these leaks don't become a common issue with air ride but i do like the softer ride!
Its holding for now!!!!!!
