04-13-2011, 09:01 AM | #1 |
who is using the factory intake and air box in their swap?
Hey guys who is using the factory air intake tube and air filter box in their swap. I only found one in the pics section.if anybody is doing this I would like to see pics and know what you did to relocate battery. Thanks!
Posted via Mobile Device Posted via Mobile Device |
04-13-2011, 02:19 PM | #2 |
meowMEOWmeowMEOW
Re: who is using the factory intake and air box in their swap?
Any particular reason why you want to keep the stock air box? Tubing and a filter is pretty cheap and available almost anywhere.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-13-2011, 03:19 PM | #3 |
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-13-2011, 06:00 PM | #4 |
I just like the factory look of it. I haven't made up my mind though.was there such thing as a auxiliary battery tray to move the battery to the other side.
04-13-2011, 11:45 PM | #5 |
I've used them on the last three truck I've built, I like the looks of them. And yes, there was an auxillary battery that mounted on the left, but I just modify the original one to work on the left.
http://www.ls1tech.com/forums/conver...-4l80e-10.html And here's the one I built back in 2005 |
04-14-2011, 07:30 PM | #6 |
Thanks,Thats exactly what I want to do!
I'm gonna have to check your build out! That truck looks sweet! |
04-17-2011, 11:32 AM | #7 |
Green club
I am using the factory air tube, but I did not use the box just a simple cone filter. I do have the box though, when I find the time I may move the battery to the drivers side and use it but until then this is the way it will look.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
