04-13-2011, 10:26 AM | #1 |
New guy garage?
Hi, new here. Trying to get some ideas and suggestions of what a beginner needs to consider having in a small garage. I'm currently clearing an area about 30'x40'-50'. I live out in the country so there aren't any codes to worry about. Any information like ideal size of air compressor, what type of cutting tools and welders, or anything you guys can offer that I might not think about.
Trying to follow a modest budget but leaving room to grow. Thanks in advance! Edit, found the right place for this information. Last edited by dhmjr; 04-13-2011 at 10:35 AM. Reason: Found answer. |
04-13-2011, 04:59 PM | #2 |
I am a Referee of life.
Re: New guy garage?
Go with a s big a compressor as you can afford/power and the same with most everything else.I would suggest you buy the best quality you can afford also.I don't think a hobbyist can really justify buying "Snap-On",or other tool truck tools so I really like Craftsman pro series.Miller has a line of welders labeled "Pro-sumer" and some (at least) feature MVP's which means the welder runs on 110 or 220.Makes for a nice ability to grow into your power at least.Unless you're planning on lots of cutting a cut-off wheel, and a couple of saws(Cut off and recip) will do a lot.
For great info on garages try www.Garagejournal.com
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-13-2011, 05:14 PM | #3 |
Re: New guy garage?
Thanks for the help!
04-13-2011, 05:56 PM | #4 |
67cheby
Re: New guy garage?
if you are running air tools , you need a minimum of a 80 gal compressor...i tried a 60 gal and it wouldnt keep up with my air tools (i am referring to air body working tools ie...da sander and inline sander, mud hogg)
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 04-13-2011 at 05:56 PM. |
04-13-2011, 06:03 PM | #5 |
Re: New guy garage?
Nice Big Refrigerator, Microwave, Refrigerated beer keg with tap on top, Stereo, Army Cot with sleeping bag, Barbecuer and a nice recliner for naps? Maybe some nice tools too!!!
04-13-2011, 07:33 PM | #6 | |
Re: New guy garage?
My theory with toolboxes is of course go big or go home like every guy out there. But really dont shortchange yourself on the box and buy too small because you'll be surprised how fast you fill it up and then you gotta go fine a new one. But listen to your woman when she tells you the 88" Macsimizer won't leave you any room in the garage, cuz well...she was right. Just don't tell her that. Most of my box is filled with Mac tools but now I go Craftsman for a lot of stuff I need. They're making some real nice stuff and they have the Pro series like posted above. You dont need to find a tool truck and they have the same warranties the big boys do and for a fraction of the price. Oh yea and before anything else, get some good lighting for the ceiling..itll save you a ton of time looking for lost nuts and bolts. My advise..start hittin up Craigslist and ebay for good used stuff. Obviously we're all strapped for cash but there's always shops closing and selling equipment for cheap. And dont forget a couple of good fans for the summertime. Have fun! Last edited by bucketObolts; 04-13-2011 at 07:36 PM. |
04-13-2011, 06:38 PM | #7 |
VA72C10
Re: New guy garage?
I agree on the largest compressor possible. Also, I'd build the building bigger than you think you need now....it's easier/cheaper to build it bigger now than adding on later. you don't have to fill it all up or put lighting in it all now...
Looking for a 67-72 swb or blazer project in or around VA. |
04-13-2011, 07:59 PM | #8 |
Re: New guy garage?
I agree built bigger, I built a 30X60 (10 years, cash all the way) with a concrete apron for parking down one side and a 60x40 drive way and it already full. Steel framed, cable tv set to Speed, 2 post lift, miller welder, plasma cutter, different areas for welding, storage, engine assembly etc. i use a smaller compressor in the shop, but have a big gas tow unit for the times i need a lot of air. Good luck on the build
04-13-2011, 08:03 PM | #9 |
Re: New guy garage?
Build it with height so you will have room for a lift...
Posted via Mobile Device |
04-13-2011, 08:13 PM | #10 |
Re: New guy garage?
Yea, 220v is a must and make sure you designate an area just for take-off parts or a donor truck. i know youre building big but space always seems to disappear more and more everyday. Get yourself a nice little welder and build a big steel work bench. Unfortunately I only rent a 2 bay residential garage and I haveto do most of my welding either on the floor if i have space or in the driveway. Then start hittin the swap meets for rusty bumpers and old hubcaps because, well, they just look cool on the walls.
04-13-2011, 10:31 PM | #11 |
Junior Member
Re: New guy garage?
My son had a shop built, I think, 30' by 40' with a 11' height to the bottom of the trusses. Now that he has had it for a while he realizes he needs an area separate to do body work and painting.
He had it built so two vehicles could be worked on at a time, but so far it has not worked that way since his wife's truck can not be parked outside since it got restored. It is not a trailer queen, but seems to be allergic to dust, lol.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-13-2011, 10:47 PM | #12 |
Re: New guy garage?
I would have a air conditioned build room that I could keep CLEAN,if I was to rebuild. Working on and rebuilding in the same space is a mess.
04-14-2011, 07:08 AM | #13 |
Re: New guy garage?
Put some mats down around work stations or benches so you can work more comfortably. Also a couple of high stools with backs for when you can sit to do your work. The guys are right about the 80 gal compressor, you will need it for body work and a blast cabinet. Add lots of tall shelves for storage, the heavy duty ones that can handle some weight. Dont forget 220 outlets for welder, oven if you decide to powdercoat, and each lift you might add. Plumb your airlines with retractable wheels so you don't have airlines all over the floor. Paint your floor if its concrete with a sealer that will keep dust and moisture down. Have fun, working on your man cave is almost as fun as working on the projects.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
04-14-2011, 07:50 AM | #14 |
Redefining LowBudget
Re: New guy garage?
a few things I would do
some sort of concrete or block knee wall so you can wash the floor or when you slide jacks to the wall and they dont poke holes in it put plywood all the way around 4 feet high......then you can hang stuff anywhere like you air lines, hoses, shelves what ever and again it protects the walls from "STUFF" poking holes Lots of wall outlets and some out front and a few in the ceiling for drop lights call your power company they can/will hook you up with a great deal on lighting.....and I have a street light out front that cost me $8 a month to run it worth every penny and since the power company owns it theres no issues if it burns out or for that matter installing it SEAL THE FLOOR BEFORE YOU DO ANYTHING....it willl keep it clean and you'll never do it after...trust me |
04-14-2011, 08:04 AM | #15 |
chrome makes it go FASTER!
Re: New guy garage?
Definitely add a sink-clean up area. Mama won't be happy with greasy hands in her bathroom. My electric chainfall sure comes in handy for moving heavy parts. Especially when I'm by myself. Sure would be nice to have a bathroom out there too. Retracting extension cords and air hoses keep the floor uncluttered. First aid kit is a must!! Gotta have some tunes. And you should consider your heat source during construction. Electric,gas,or woodstove. Its cheaper and easier to do it now than later. I would consider a washing machine for greasy jeans, shop rags and coveralls. DO NOT wash your nasty shop clothes in the family washing machine. You'll be sleeping in the shop if you do
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
04-14-2011, 08:21 AM | #16 |
Re: New guy garage?
That's what I'm talking about! I'm the world's worst about hindsight and since I'm starting at ground-zero these ideas are a great help.
Thanks again! |
04-14-2011, 06:21 PM | #17 |
Re: New guy garage?
Watch CL for cabinets.They work great for storage of tools that don't fit the BOX and can be used to store consumables.They're also easy to build a 2X top for use as a bench.Old school or gym lockers can also be used.Find some cardboard or plastic bins for smaller stuff.Bolt bin.A 3-4 ft air wand for blowing dirt etc. off of the shelves and things on them.A stand or rack for steel if/when you do fab work.^ welding table ^.I also like outlets hung from the ceiling to a height of about 7 ft.I can reach them and don't have to run so much extension cord.They are usually run in what is known as S.O. cord.A laundry room style sink works great for clean up and for cleaning parts(most water based degreasers are Bio friendly).When you think you have enough lights ,double them,then add a few in main work areas( be aware of the tasks to be performed there so you can adjust mounting for shadows).Get some task lights to use,I like the High intensity ones on a stand.You're not gonna get any younger and extra light makes your glasses stronger(LOL).A fire cabinet is nice to have for paint etc but you can get by with an old refrig,Just don't forget which is which when it's beer 30.
Buy a vise or two.One small/med for smaller stuff and the hugest big monster that you can solidly mount.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 04-14-2011 at 06:23 PM. |
04-15-2011, 07:58 PM | #18 |
Re: New guy garage?
My shop is over 20 years old now and my most valuable suggestion is:
Don't do a thing until you've spent a lot of time planning exactly what you want for now and the future. My shop is a 50'x 75' steel and purlin structure that's 12'tall. IT"S FULL!! I built it 500'from my house thinking of all the motor noise.Works great but it's a lot of walking. It's too close to the pond-I've removed several snakes over the years. I do have power,phone,water,etc. You can never have enough storage,receptacles,and lighting.Repeat this 10 times! Whatever you have in it,if you ever plan to move it,put it on wheels now! Designate storage.Designate work areas.Do not mix! Get and have handy fire protection!I suggest a fire extinguisher and a water hose,right where you're working. And,don't forget security.Make sure you can lock it up. If you're going to be in there alone most of the time(most of us are)have a cell phone handy (if not in your pocket),just in case! Just my 2 cents. Mike. Last edited by 100%Chevy; 04-15-2011 at 08:00 PM. |
04-16-2011, 04:08 PM | #19 |
Re: New guy garage?
You should check out Garage Journal Forums
http://www.garagejournal.com |
04-19-2011, 11:22 AM | #20 |
Re: New guy garage?
I just built my shop last year it is a 30x40 with 10 foot walls and scissor trusses so that the center of the garage has 14 feet of height (really opens it up) highly recomend it.I put a two foot just out in the center bay and angled my garage door tracks up along the ceiling so I have clearance when there is a car on the hoist(otherwise you will not be able to open the garage door with a car on the hoist). lots of lights and lots of electrical outlets even in the ceiling and all around the outside. I also put 220 in the ceiling for the hoist when I get one. I sheeted my shop inside with osb and seamsealed all the seams and painted it white( If you seam seal the joints it takes away the black border around every sheet of plywood and looks really good when done). I bought a DV air compressor that will keep up to anything I can throw at it (Must buy a two stage air compressor!!! I spent 2700.00 on the compressor but worth every dime ). As far as tools they can be added at anytime as needed, someone mentioned craigslist and I think that is a great way to buy good used tools especially if its a hobby garage. Have fun with the new shop and once you have it you can't imagine not having it.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
04-19-2011, 11:24 AM | #21 |
67cheby
Re: New guy garage?
Sweet shop !!
04-19-2011, 12:40 PM | #22 |
Re: New guy garage?
Not Trying to hijack but here is a recent pic
04-19-2011, 12:44 PM | #23 |
67cheby
Re: New guy garage?
too....COOL nice decorations also
04-19-2011, 01:43 PM | #24 |
Re: New guy garage?
Very Cool!!!
04-19-2011, 01:48 PM | #25 |
Re: New guy garage?
I'm guessing that's a heater up in the corner. Is there another in the opposite corner as well and is that enough heat?
