rebuild factory radio on an 87?
I have the factory knob radio in my 87 suburban and want better sound. It only works on the right side and crackles on the left.
I don't need an ipod hookup, I can use an antennae adapter for that. Has anyone had the factory radio cleaned and repaired? Or found a decent inexpensive after market knob radio? I replaced the back speakers but haven't done the dash ones yet. |
Getting Old; Going Broke
Re: rebuild factory radio on an 87?
There is a huge difference between the crystal tuned radios and the electronic tune radios. Which do you have in the 87? Either were available that year. The ETR radio should have a digital face/display, but still the knobs.
Or you could go with what the 89-91 Burbs had in them, just need a different bezel and cut your dash some. Either way, replace the speakers with something a bit nicer and listen to the difference it will make.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. Last edited by RandyP; 04-13-2011 at 03:04 PM. |
Cruzzzn' Vet
"cut your dash some"
Getcha Pull
If your cutting it for a factory radio, that's not so bad...
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
Exactly. Had we not just put a used chunk in my 87 (from where the PO had a cd player installed), I would have just made the hole larger and went with a bigger GM radio. Especially since I have like 10 cluster bezels for them.
![]() But the ETR radio does sound better, a lot more crisp and no fading in and out at all.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
I have thatradio on the top in your picture, the ETR one
it works just sounds terrible on the left side |
