steering column woes !
Hi Folks,
I am looking for some advice on how to secure the part of the steering column that holds the auto trans. shift indicator screen. This is the collar piece that sits directly behind the steering wheel, and the turn sigal switch bolts to it. It also sits in front of the collar that rotates as you change gears. it flops around when you move the gearshift lever. It looks like it is just supposed to rotate to lock into place, but it wont stay where it is supposed to...any suggestions ?? PS...I did search this site, couldnt find answer |
Re: steering column woes !
ALSO...I am tryin to add some pics and cant find the " pictures and albums" link in my control panel as described in the FAQ section
the pollock
what year? im parting a 69 cab right now if you need peices
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
the truck is a 68 ( not the one in my profile pic..thats a 71 )..I'm hoping to have this done today !! do you think I am missing a piece that hold this in place ??
thanks |
There are some "feet" stamped into the upper end of the main column tube. With the shift housing and wires ALREADY in place this piece goes over the end of the column and turns to lock behind the "feet" when the screws pull it up against them. I make sure that the column and bracket are in the correct orientation using where the "4 way flasher" switch is/will be located. The kind of triangular piece that the turn signal assy screws to is the key and it is notched so it will only fit the tube one way. DO NOT forget the spacers and bearings that go in too! It can be quite a handful with all these pieces trying to go every which way at once, but if I did it, (several times!) you can do it!
Best wishes, Les |
On the pics, when you hit the post reply box, scroll down to the box below the message box (additional options) and you will see a box labeled "manage attachments". That is how you add pics.
Sorry, never been into the column though. Good luck
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress Last edited by dmack91; 04-14-2011 at 01:26 PM. |
Les, Thanks your info was spot on !! The 3 screws pulling against the feet was the key. Heres a pic of what I'm workin on. Now if I can get the new door latch assemblies to cooperate !..Jeff
the pollock
dude even w just a cellphone picture it's a sexy beast
Yeah, and it looks a hellova lot nicer than mine. Next time I'll be callin YOU for help! ;}
