04-14-2011, 12:56 AM | #1 |
fuel sending unit
i have a 70 c10 that was originally an inline 6 truck. i have since switched out the 6 for a small block. the fuel sending unit needs to be replaced. question is, do i have to use an original unit for a 6 for accurate reading, or can i just get a unit for a v8 and install.
04-14-2011, 01:10 AM | #2 |
Re: fuel sending unit
My understanding is that the sending unit is the same, it is the fuel line coming out of it that is different. I think the the I6 is 5/16" where the V8 is 3/8".
I am sure those who know more will chime in.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
04-14-2011, 08:44 AM | #3 |
Fuel line size and the connection is the only differences. In 69 I know the V-8 307 2 barrel carb fuel sender unit came with the smaller line also as stock. Since then I replaced the carb with a 4 barrel, I have had no starving fuel issues for several years. Doubtful unless you are running dual carbs you would have a issue with fuel starvation in a stock setup.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-14-2011, 12:37 PM | #4 |
Project Junkie! Fishing Poor!!
The only difference is the size of the tube. If you install one from a V-8 then either you will have to find 1/4" an adapter, or change the fuel line going through the floor of the truck. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
