Old 04-14-2011, 02:57 PM   #1
72gmcshorty
72gmcshorty's Avatar
Help with shocks...
What is the quality level of the shock brands out there? I'm assuming KYB near the top, monroe on the bottom. Where does doetsch tech, belltech,fit in? Any others?
Will the shock limit how low my vehicle can go when i air out my bag? (will it prevent me from bottoming out when i air out?)
I know when you put a 3" drop spring, you've dropped your truck 3 inches. When you replace the spring with a bag, how much drop do you now have...
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 04-14-2011, 04:21 PM   #2
SCOTI
SCOTI's Avatar
Re: Help with shocks...
I can't answer your first question because I like to use stock replacement shocks & make my mounts to work w/them (or choose a similar vehicle w/a 'better' length). The other stuff is answered in red....
Yes, it can do both if the optimum length isn't used.
I know when you put a 3" drop spring, you've dropped your truck 3 inches. When you replace the spring with a bag, how much drop do you now have...About the same. 3" drop @ ride height & more when the air is purged.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-15-2011, 03:18 PM   #3
72gmcshorty
for the rear.....i have a bag, bolt-in notch and the shock relocator brackets. Do i buy just stock length shocks?
***just noticed i hit the 1000 post mark!!****
1992 Gmc 2wd
Old 04-15-2011, 03:48 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
They will work if you are running a 2" block and a button bumpstop, or a 1.5" block and a tall bumpstop(for 15" wheels). Otherwise, the shocks will be too long.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-02-2011, 06:29 PM   #5
72gmcshorty
ok, i measured my rear aired out and came up with 11 1/4" center to center. I don't have a body or wheels on my frame so i'm not sure what my aired up height would be. Anyone have that measurement handy. I have bag and CPP notch.
1992 Gmc 2wd
Old 05-02-2011, 06:47 PM   #6
SCOTI
SCOTI's Avatar
Research what the air bag mfr recommends for ride height on your particular bags. Most dbl convoluted bags are around 2.8 - 3" @ full compression & between 5.5 - 6.5" @ recommended ride heights (sleeve type bags are slightly longer).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-02-2011, 10:25 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Easy way to figure out what you need online:
Go to the Monroe website - http://www.monroe.com/ - and figure out what your stock shocks are.
Once you have this info, use the following guide to determine the mounting style of your stock shocks. Then, you should be able to find a shock that meets your mounting needs with your required lengths.
http://www.monroe.com/assets/downloa...engthSheet.pdf
Also a good idea to cross-reference your chosen shock's application to make sure the valving will be similar to your truck's.
Happy hunting!
-Chris
Old 05-02-2011, 10:33 PM   #8
SCOTI
SCOTI's Avatar
Also a good idea to cross-reference your chosen shock's application to nake sure the valving will be similar to your truck's.
Happy hunting!
I think this is an often overlooked aspect to finding the best replacement shock for a 'custom' application.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
