68 front suspension swap
Im sure this topic has been covered several times before, but I would like to make sure Im not going to open a huge can of worms. I recently purchased an 82 c10. Ive seen where guys have swapped the front suspension, crossmember and all in older trucks. The 82 has dropped springs and spindles and I would like to slide all of this under my 68. Ive been told and read that its ALMOST a bolt in swap but I would still like to solicit some advice to make the process as smooth as I can. Will I need any other parts than the ones from my donor truck? Which steering box should I use, both have power steering? Which motor mount towers should I use, both are v8 trucks and Im also using the engine/trans from the 82 in the 68? And any advice in general would be very much appreciated, thanks
Re: 68 front suspension swap
its pretty much a bolt in deal you dont even need to swap cross members i actually like the 68 A arms as well they have smaller bushings better for ground clearence all you need to do is swap the ball joints and i would use the whole steering from the 82 box tie rods everything thats what i did on the 68 im working on but the A arms bolt up in the same place the cross members are pretty much identical you can go either way on the eng mounts i like the 67-72 ones i think they look cleaner
or you can always go with that porter build set up that everyone and their mom has gone with i think its allot of money to spend when you can do a simple z in the frame and get the same result for a fraction of the cost but thats just my opinion i know allot of guys swear by porter built because its bolt in
sweet, its nice to know that i have alot of options, i really appreciate the feedback- im really glad someone with first hand experience got back to me. and as far as that porter setup they can have it, im building a clean low budget truck, i dont have the money for all the convenient kits that are available. thanks again and i love the truck your building, 68's are my favorite
no problem im glad i can help feel free if you have any other questions there are allot of guys on here that know allot about these trucks as well its a great site
Swaped a 86 crossmember to my 68 and I had to drill one hole on each side and enlarge on hole and it bolted right back up.
Yea it's a simple project and even easier if you just swap the arms unless your goin from 1/2 Ton to 3/4 ton the upper arm studs are a diff size
Posted via Mobile Device |
wonderful, appreciate the help- i think the guy who told me it wouldn't work just wanted my dropped spindles and springs- thanks again fellas,
hahahahahha thats nice of him lol good luck with your build
just got the time to swap that front end today- crazy easy- thanks again for the help guys
My 68 burb has the newer style control arms. Ball joint swap and your in business buddy.
Good luck. Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
