Old 04-15-2011, 11:46 AM   #1
billetproofcustoms
billetproofcustoms's Avatar
removing leaf springs...how to??
Hey guys,
I have a 75 c10 with a 8 spring pack on the rear, hate the ride in the rear..way too stiff, I dont haul or tow anything. I want to do the leaf removal/shackle setup. I have been reading all the posts I can find on removing leafs from the pack to lower and soften the ride but none of the posts explain enough, my questions are about removing the tension from the pack, seems i need 2 c clamps and jackstands...but I am still unclear on the procedure for relieving tension/removing the center pin holding the pack together..
I would just do a flip and not touch the springs, but I would still have the stiff ride? correct??
Can someone post a how to??
billetproofcustoms is offline   Reply With Quote
Old 04-15-2011, 01:38 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: removing leaf springs...how to??
Just C-clamp the leaf pack together, on each side of the center pin. Then simply grind and remove the pin...unclamp and remove the overload, perhaps the one above too...then reassemble using new centering pins. I wouldn't put a shackle in yet, wait and see how much lower it sits when reassembled and go from there.
It is easier to do this with the leafs off the truck in my opinion.
bigblock73 is offline   Reply With Quote
Old 04-15-2011, 01:51 PM   #3
billetproofcustoms
thanks for the info, but do i need to support the frame on jackstands? tires off? differential on jackstands?
Old 04-15-2011, 01:58 PM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Yes, you will have to unbolt the diff from the springs, and there's a lot of weight there. good luck.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-15-2011, 02:46 PM   #5
jitteryguy
GoatLube Experss
jitteryguy's Avatar
put jackstands under the frame,place the jack under the axle then loosen one side then remove the other U bolt, let the jack down till the axle is clear of the spring. it's easyer to work with if you take the spring pack out but you dont have to. the pin is a 3/8 bolt with a round head, it will be too long when your done. get some new grade 8 bolts and grind the head down till it's round. after everything is apart you can test fit the bolt head in the axle and adjust acord'nly. use long C clamps cause the spring will spread way out. remove how ever many spring's then get a long 3/8 bolt or pin to keep the springs line'd up while you reclamp em, replace the pin with the new bolt.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 04-15-2011, 08:23 PM   #6
lilpoindexter
lilpoindexter's Avatar
Why not just grab a smaller set of leafs from the Junkyard?
lilpoindexter is offline   Reply With Quote
Old 04-15-2011, 08:50 PM   #7
bigblock73
yeller
bigblock73's Avatar
Because lighter duty leafs are shorter..then you have to relocate the hangers on the frame...not easy to do.
Old 04-15-2011, 10:52 PM   #8
80SPORT
80SPORT's Avatar
Also the bolts are often frozen in the shackles ...if you just pull some leafs out you don't even need torches ......
80SPORT is offline   Reply With Quote
Old 04-15-2011, 11:15 PM   #9
dropd80s
dropd80s's Avatar
Sometimes, those U bolts can be as bad or worse than the spring eye bolts.
dropd80s is offline   Reply With Quote
Old 04-15-2011, 11:29 PM   #10
jitteryguy
GoatLube Experss
jitteryguy's Avatar
very true,
but AutoZone stock's Ubolt's so if it come down to it, you could cut the Ubolt. I try to spray WD40 on stuff like that several times start'n a few day's befor the project. dont always work, but most of the time it does.
'85 1/2 ton CCSB
'92 S10 350/350
Old 11-01-2011, 10:30 AM   #11
kenzie
Hey I am new to this community, but I just wanted to drop a thank you for this thread and a few others. I used them to help me do my first leaf removal project. It went well. Also did a cut spring up front. I am about to post a thread in the forum for the age of my truck, it's a 97 suburban.
thank you for your help everyone!
kenzie is offline   Reply With Quote
Old 11-01-2011, 11:24 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum kenzie. Glad you were able to use the advice offered.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
