Not too old to learn
What I really need is pictures of cab tops in white.
Where are the separation lines both inside the door frame and the back of cab ? I figure the A pillar will be painted white also. My truck is a 68 and is solid color now so I have no reference points to go by. I will need to add the chrome strip under rear glass, so need to see where the color line will be. ![]() Thanks.
1968 C10 a way to long restoration. |
Re: How to paint white cab top ?
I painted the window frame white on my door. Then I simply put a tape line down even with that all the way around the back.
I didn't add the chrome strip. I was going to put a piece of trip tape over the line but so far haven't bothered. The a-pillars I painted white too.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Here are some photos of my family 68 two-tone with original paint, FWIW.
![]() Join Date: Feb 2011
The stock paint on my 67 is only to the drip rail, no door or A-pilar. Don't have a better / closer pic.
Brad 67 Chevy SWB stepside - http://67-72chevytrucks.com/vboard/s...d.php?t=449426 89 Ford Bronco 92 Suzuki Sidekick 94 Kawasaki Vulcan 750 06 Honda Aquatrax |
67 was painted differently than 69-72 , not sure about 68.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Looks like a 68 was painted like the 67 with the pillar and door frame not white. I guess if you are not going for a 100 % correct truck you can paint it like the 69-72 tops.
#8 | |
http://www.67-72chevytrucks.com/vboa...d.php?t=143327 http://67-72chevytrucks.com/vboard/s...d.php?t=346534 |
on my 71 GMC burb all pillers exept the d-piller witch is white look like they used the drip rail as the break
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
i didnt paint the door frames or A pillars on mine.
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
BLACK SATIN
![]() Join Date: Jan 2009
you can look in my album if you need any more. I am a fan of white tops, too.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new 67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering 85 C10 Silverado- 305ci |
