The Crazy Machanic
np203 questions
Im in the middle of a build of a once a 1986 4x4 1/2 ton automatic 700r4 350 truck. Its now going to be a 3/4 tonish 4x4 granny 4 speed with 6.2 diesel also swapped axles.
now i have a np203 which i know is all time 4x4 but i have manual locking hubs would that be basically 2wd or do i need to do something about this?
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Re: np203 questions
That would alowed the front hub to turn free, but your gearz are still going to trun. You can run a 208 or a 205 they would work better
It's not what you buy, It's what you build Last edited by Rbcustoms; 04-16-2011 at 02:41 AM. |
Re: np203 questions
You can get a kit to "part time" you no203
Posted via Mobile Device |
Re: np203 questions
if you put lockouts up front and leave them open or unlocked, you will not go anywwhere. The front driveshaft will spin while the rear does nothing. You need to get the part time kit that goes into the t-case. There are two, one is better than the other and more expensive, but if you plan on adding bigger tires and offroading, gonna want it.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
#5 | |
The Crazy Machanic
Re: np203 questions
that is what keeps confusing me so if i run the front hubs unlocked and the t case in gear the truck will not move?
Re: np203 questions
Yep driveshaft will spin. I think that the front spins first, then power goes to the rear. Not real sure how it works. I had a truck that had the 203, swapped in a set of lockouts, unlocked them and put it in, the front shaft was spinning like the truck was doing 60. Only way to drive the truck is to put it in 4 lock, then sends power to both front and rear.
Getting Old; Going Broke
Re: np203 questions
Well, my 79 K5 has the 203, the front hubs are unlocked and it is in HI, moves just fine. Unless it is just so worn out that it is actually in HI LOC, but I don't think it is. One notch up from where I have it is Neutral, and I've had to do that a few times recently to push it around the shop after making it a non start for various reasons.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
#8 | |
Re: np203 questions
So when you put a set of lockout hubs on a truck with a 203 and leave them unlocked, it's basically the same thing as having one wheel jacked off the ground with an open differential. When the 203 is shifted to either Hi Loc or Low Loc, it locks out that internal differential and will therefore allow the truck to drive with the hubs unlocked. As has already been said, there are a couple of kits available to convert the 203 over to part time operation. The kits basically eliminate that differential and make it so power always goes to the rear driveshaft. The "Hi" & "Low" positions become 2Hi and 2Low, while the "Hi Loc" & "Low Loc" positions become 4Hi and 4Low. Or, depending on how you plan to use the truck, you could leave the 203 as-is and replace the lock out hubs with the solid splined "pucks" that were used in factory 203 equipped trucks. |
Moderator
![]() Join Date: Oct 2008
Re: np203 questions
The NP203 has a lockable differential just like front and rear axles. In 4HI and 4LO it's just an open diff sending power to the driveshaft that turns easiest so it doesn't bind up on smooth pavement. In 4HI Lock and 4LO Lock the diff locks and it operates like any other transfer case in 4x4. If you unlock the hubs the truck will not move in 4HI or 4 LO. I don't know what happens if you are in the 4HI Lock or 4LO Lock positions. If it moves in the "Lock" positions it may not be good for the internal diff.
The NP203 is heavier than a dead horse... Mile Marker made a full shaft part time kit for the NP203 the cheaper shaftless kits don't have good reputations. As a bonus you do get a 2LO position with a converted NP203. The NP208 is cheap and does have a much better low range 2.76:1 when compared to the 203 & 205 that have 1.96:1 low range and should hold up fine behind the 6.2. Ray posted the same thing while I was writing. ![]() Last edited by hatzie; 04-17-2011 at 01:42 AM. |
#10 | |
Re: np203 questions
The 208 is also significantly weaker than a 205. I have seen more than a few 208s leave their guts behind. |
Moderator
Re: np203 questions
I've plowed snow commercially with Ford, Dodge and GM trucks that had NP208 & NP241 cases. Snow plowing is rough on everything. The transfer cases held up for 150k+ miles of commercial snowplowing and landscape trailer towing. In that same number of miles we went through 2-3 transmissions and a couple front axles. Low range with the newer NP208 & NP241 trucks was noticeably better for pushing snow around than the old NP203 Dodge Power Wagon we kept as a backup rig.
![]() Join Date: Jul 2012
Re: np203 questions
Anyone know where I can a get a shaft part time conversion kit for a 203?
Ron |
Re: np203 questions
Remember np203s use light oil 30 weight tops i prefer 10-40. ALso if you part time it get some half inch fittings and extend the filler 2 inches higher so the case holds 2 inches more oil. The part time kit stops the pump in the 203 . The extra oil lets it slosh lube.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
#14 | |
Re: np203 questions
Also, nice thread necro.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
#15 |
78K & 79C Jimmys
Re: np203 questions
i dont drive mine everyday, so when i do i drive with my hubs unlocked ,I drive the first 10 min or so with the axles locked ,undo it and they are lubed
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#16 | |
Re: np203 questions
Ron |
#17 |
Re: np203 questions
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 Last edited by 83GMCK2500; 04-17-2013 at 05:26 PM. |
#18 | |
Re: np203 questions
Yes that shaft .. Dont see where I can purchase it anywhere..Ebay or mile marker. Guess I gotta use the cogs., unless your seeing where i can buy that shaft somewhere???? I dont see it for sale anywhere?? Ron |
#19 |
Re: np203 questions
Your 203 (and mine) has HI, HI LOC, LO, LO LOC. HI is you're in high range 1:1 and have 20% of your power to the front, 80% to the back. HO LOC is an even 50/50 split of power but still in 1:1 gearing. LO is 20%/80% but 1.96 geared. LO LOC is a 50/50 split in that gearing. I personally plan on running a 205 with the full time acle these trucks came origional with. Then all i gotta do is push a lever and BAM 4wd.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
