Old 04-16-2011, 06:13 PM   #1
66 GMC 351E
66 GMC 351E's Avatar
Trick to removing clutch z bar?
I've got the rods unhooked, the nut, lockwasher and lock clip removed and can lift it out of the mount on the frame, but I can't pull it off the ball stud on the motor side. I can't lift it high enough to clear the bracket on the frame. Is there a trick to getting it out of there? '66 GMC 3/4 ton with V6 351 E.
66 GMC 351E is offline   Reply With Quote
Old 04-16-2011, 06:42 PM   #2
bama63
bama63's Avatar
Re: Trick to removing clutch z bar?
slide a jack under the trans and pick it up a bit until it clears the bracket and slide it out
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 04-16-2011, 10:29 PM   #3
66 GMC 351E
That did it! Out in 30 seconds. Thanks bama.
