Old 04-18-2011, 01:15 AM   #1
kurts704
Power drum brakes???
I have a 67 C10 4x4 stepside. It has manual drum brakes. I'd like to upgrade to discs but don't have the cash right now. Can I run a power booster to the drums for a little help stopping? This thing doesn't like to slow down!
kurts704 is offline   Reply With Quote
Old 04-18-2011, 02:16 AM   #2
gonnuts
gonnuts's Avatar
Re: Power drum brakes???
my 67 2WD has power brakes on drums.
gonnuts is offline   Reply With Quote
Old 04-18-2011, 03:23 AM   #3
Jeffs70
Jeffs70's Avatar
yeah back in those days it was optional if im correct.
Jeffs70 is offline   Reply With Quote
Old 04-18-2011, 07:02 AM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
best $$ you can spend on your truck...trust me !! it takes about an hour and a used one from the board will run you about $60 with the brackets and all ........it up graded my old drums so much that now I'm in no rush to do my disc/drop swap
Hottrucks is offline   Reply With Quote
Old 04-18-2011, 09:45 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I upgraded my White '67 and I didn't even have to unhook the brake lines... Nice improvement.
LockDoc
Leon
Old 04-18-2011, 02:10 PM   #6
dmack91
dmack91's Avatar
Ditto. Best upgrade I have made. Make sure when you get it that it has all of the brackets and linkages - makes it a simple hour swap, as LockDoc said.
Just go easy bending the steel lines to the MC and it will be easy.
TIP - unbolt the MC before trying to remove the linkage bolt from the brake pedal - it will drop it down so it will clear the steering column, otherwise, you will have to drop the column.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is online now   Reply With Quote
Old 04-18-2011, 02:14 PM   #7
dmack91
dmack91's Avatar
Here is the link I used - made it simple.
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
Old 04-18-2011, 09:21 PM   #8
kurts704
Thanks for the info guys, and that's what I'll do, just add a power booster. I'm new to the site, how do I find the parts for sale? Thanks
Old 04-18-2011, 10:25 PM   #9
LockDoc
LockDoc's Avatar
Just scroll down to the bottom of this page and you will see the "Forum Jump" box. Click on the down arrow on the right side and scroll down to "The 1967-1972 Chevrolet & GMC Pickups Parts Board" and click on it. It will take you to the parts for sale forum.
LockDoc
Leon
