04-19-2011, 05:22 PM | #1 |
Getcha Pull
Shrinking A Fuel Gauge
Thought I'd try and take a oil pressure gauge, and turn it into a fuel gauge...
Parts Needed 1x Fuel Gauge 1x Oil Pressure Gauge (Or gauge of your choice...) 2x 1/8" Rivets Tools Needed 1x Can of Brake Cleaner 1x Cotton Rag 1x Rivet Gun 1x 1/16" Drill Bit 1x 1/8" Drill Bit 1x 3/8" Drill Bit 1x Drill... 2x Jewelers Screw Driver First thing I did was take a square and made sure the marks on both gauges matched. As far as I can tell, they do. Next I set the needle of the fuel gauge at 1/2 tank and used the two screw drivers to gently pull the needle off. Making sure not to move the needle from the 1/2 position. After this I repeated this process on the oil pressure gauge. Next I took the fuel gauge and laid it face down on a cloth. Using the 1/16" drill bit I drill out the old rivets. Then using the 1/8" drill bit I enlarged the holes on the mechanism it self. Followed by the 3/8" drill bit to "bump" the holes to knock off the burs. Fuel Gauge mechanism (left) next to the oil pressure gauge (right). Repeated the last step on the oil pressure gauge, but instead of enlarging the holes on the mechanism, I enlarged the holes on the gauge face. Taking the fuel gauge mechanism, and the oil pressure gauge face I stuck the rivets through and tightened both the rivets to make sure it is lined up right. The "popped" the rivets. Now because oil pressure reading aren't going to look right I took some brake cleaner, and a rag to rub the numbers off. At this point you could use water slide decals, or whatever you prefer to add proper fuel level marks. And finally add the needle from the oil pressure gauge. Making sure to set it at 1/2 liked you pulled the old needle off. That is the easy part, now I gotta figure out what to do for a tach...
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
04-19-2011, 08:06 PM | #2 |
Re: Shrinking A Fuel Gauge
Nice job! but an awful lot of work, you could of just bought the small fuel gauge for a tach dash. LOL
God Bless, Terry |
04-19-2011, 08:28 PM | #3 |
Getcha Pull
The whole thing took me roughly half hour. The idea was to not have to pay out the back side for a tach dash. I did this for the cost of zero because I had the rivets laying around. If I was going to do one for use, I'd spend a couple dollars for black rivets to fade it away.
04-19-2011, 08:40 PM | #4 |
Great Idea , Looks good too and its thrifty
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237 |
04-23-2011, 06:54 AM | #5 | |
Moderator
The white blocks on the gauge studs are resistors wired in parallel with the needle coil. You could probably swap the ballast resistors on the back of the gauge to re-purpose the unit. Nice to know that brake cleaner takes off the lettering. Last edited by hatzie; 04-23-2011 at 07:11 AM. |
04-23-2011, 07:24 AM | #6 |
78K & 79C Jimmys
looks good a little dab of paint or marker might hide those rivits
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-19-2011, 08:52 PM | #7 | |
NICE WORK!
Jeremy I have done so much, for so long, with so little, I can do anything with nothing! 1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.) 1986 GMC Suburban 3/4 ton 4x4 2014 GMC Sierra LTZ Z-71 Crew SWB |
04-19-2011, 09:01 PM | #8 |
Did you just wipe away the 0, 30 & 60 and leave the original lines in place? Or did you wipe it all away and put new lines back on it?
04-19-2011, 09:22 PM | #9 | |
Getcha Pull
Thanks for the kind words, guys!
04-23-2011, 08:16 AM | #10 |
GM Parts Guy
I really like that idea! I may have to try it withg a couple of old clusters
I have laying around!
1975 Chevrolet C-10 Custom Deluxe (DD/WIP) 1989 Chevrolet C1500 reg cab stepside (Winter Truck) 1977 Harley Davidson XLH 1000 (Summer Cruiser) |
04-23-2011, 08:50 AM | #11 |
Any Idead where to find matching decals?? Looks great
04-23-2011, 11:30 PM | #12 | ||
Getcha Pull
Yep. I could actually get it to rub off with pressing my finger on it, but that would be very time consuming... brake cleaner, and a rag did the job perfect. Didn't touch the black finish... Quote:
I think the easiest way to go about it would be a set of white faces. Otherwise I would just stick the old gauge in a flat bed scanner, and print up some new markings. I also have pondered using LED's to mark the gauge. Green for full, amber for half, and red for empty. A set of those for all the gauges would be the bees knees. http://cgi.ebay.com/ebaymotors/1980-...item53e00876df
04-24-2011, 09:51 AM | #13 |
Moderator
08-01-2015, 09:22 PM | #14 |
I just wanted to at that I have done this simply by swapping the resistors one the back as Hatzie said and I works great. In fact it works without even swapping the resistors. In fact all of the ballast resistors that I have are ~90 ohms.
08-02-2015, 12:08 PM | #15 |
I have a gauge out of a van dash I am going to put in the clock position.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
08-05-2015, 01:28 AM | #16 |
This is a rather ingenious idea as you could technically do this and have a fuel gauge for both tanks as well as either have a water temp and oil pressure or some other gauge. Or just use one gauge and the still have 3 criticals and a hole for perhaps a tach.
Hmm you have just given me an idea for a gauge layout. |
08-08-2015, 10:22 AM | #17 |
There are inexpensive kits (less than $20) that allow you to print your own waterslide decals. It could be used to print whatever you wanted the gauge to say. They are used a lot in model building, most hobby shops sell them.
08-09-2015, 12:11 PM | #18 |
Moderator
2 small fuel tank gauges and omit the volt gauge...
Or a C40-60 tach/fuel gauge and a small fuel gauge.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
