Old 04-19-2011, 05:36 PM   #1
badblu97
Double 6's
badblu97's Avatar
Almost FED UP!!!
So I am doing the power steering conversion on my '66, one of many things that are getting upgraded. My buddy called and said he was having problems getting the bracket to bolt, as in: it wont! Its a 1968 327 (I ran the numbers) with apparently is terribly hard to find as far as brackets go. I have three different pumps, all with different brackets, and none of them line up. The engine still has factory ramhorns, with two threaded holes facing the front of the engine. Its a short water pump front end, and all the brackets I find are almot $100, and I dont even know if they will work...so where do I go from here? The shop has already burned in the adapter from CaptainFab, mounted the box, and shortened the steering shaft, so Im all in. Im also stuck....some one HELP!!
Street Glidin!
1966 LWB Custom Cab (sold)
1982 Short Fleet (under the knife)
1998 S10 2wd Fleet
2007 Chevy Silverado Crew
2007 Harley Davidson Street Glide
badblu97 is offline   Reply With Quote
Old 04-19-2011, 05:49 PM   #2
scotts62
One day...
scotts62's Avatar
Re: Almost FED UP!!!
ya sounds like it.. um why not fab one or call the place for the ones that are $100 and see for sure and if not see if you can return them?
You may have better luck in the engine forum, ill move if you would like?
Scott
93 crew cab build
Project 62
Old 04-19-2011, 05:51 PM   #3
badblu97
Double 6's
badblu97's Avatar
move away! Thanx!
Street Glidin!
1998 S10 2wd Fleet
Old 04-19-2011, 06:16 PM   #4
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
Are you running V belts? Are you going for pretty, or functional?
I would try something like this: http://www.speedwaymotors.com/Small-...cket,3137.html
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 04-19-2011, 06:30 PM   #5
wiggins
wiggins's Avatar
May have you covered. I am doing a 1968 BB truck and the power steering in 68 (Only) if I remeber right, was different. I came across this guy in Az that usually has any bracket/ pully you need. He goes by Big Block Jim or Jim @ 480-981-3096. He was very helpful to me. Hope this helps.
Preserving American History one truck at a time.
wiggins is offline   Reply With Quote
Old 04-19-2011, 11:33 PM   #6
Captainfab
60-66 Nut
If you can post some pics of the pumps and brackets that you have, we can determine which one if any of the ones you have will work. With a short water pump small block, you have to have the short water pump PS brackets. There are several variations, but they will all work. The most common ones that I find are from the '67-'72 trucks. Post a pic of your crank and water pump pulleys too.
Old 04-20-2011, 07:51 AM   #7
Jessechop
Shouldnt the pump mount to the block and the alt to the manifold? Thats the way my 68 is, unless of course you have heads with accessory holes
Jessechop is offline   Reply With Quote
Old 04-20-2011, 08:16 AM   #8
shortbed70
shortbed70's Avatar
For an easy/ clean install why don't you look into running a remote resevior pump like I ran. (last page of my build) it was like 150 off eBay for the whole thing pump,lines,resevior and fittings.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-20-2011, 08:40 AM   #9
badblu97
Double 6's
badblu97's Avatar
heres the pics....not the best, Im gonna ride out there today and work a bit more on it....I may be fabbing up something, I just dont have the cash!! The right photo shows the drivers side, and you can see the pwer steering pump at the bottom, and that bracket is actually a alternator bracket. we were fishing at this point, obviously. Im just lost as to what to do right now....
Street Glidin!
1998 S10 2wd Fleet
Old 04-21-2011, 12:29 AM   #10
Captainfab
60-66 Nut
That pump and bracket you have there is for a long water pump small block. What you need isn't anything specific to a '68 pickup. You just need a pump and brackets for a small block with a short water pump. Also in looking at your crank pulley, you don't have a groove right up next to the balancer. That is where the alternator belt will need to be with a short water pump setup.
Do you have access to a long water pumnp and all the accessory brackets? If so you might be better off convertion to a long water pump.
Here is a pic of a short water pump small block alternator drive. This is the only one I've found so far. I'll keep looking for a PS setup.
Edit: I found an illustration and an older for sale thread with a couple pics.
http://67-72chevytrucks.com/vboard/s...power+steering
Old 04-21-2011, 07:57 AM   #11
badblu97
Double 6's
badblu97's Avatar
ok, so I got a couple of billet pulleys from a buddy, put the alternator back in the stock spot, and we are fabbing a top brakcet for the power steering pump. The bottom bracket on a donated pump will work. Looks like everything is shaping up....hopefully...lol. Thank you to all who have chimed in! I LOVE THIS FORUM!!
Street Glidin!
1998 S10 2wd Fleet
Old 04-20-2011, 10:23 AM   #12
wiggins
wiggins's Avatar
Thats the way they did em in 68',remote resevoir
