![]() Join Date: Jul 2007
LQ4 to carb and now wanting FI
Kind of an interesting situation. I picked up a LQ4 out of a totalled 2006 Yukon about a year ago. For simplicities sake, I decided to go with a carb setup since the intake that was on the motor was shot anyways. Got it installed and it runs like a champ... My only issue is this past winter reminded me how nice it is to have a fuel injected setup.
So my question is: Would there be an easy way to get this thing converted to FI? Anyone that makes an entire setup... intake, fuel rails, computer, harness? |
#2 | |
Re: LQ4 to carb and now wanting FI
I have my eye on the professional products one (Summit part PFS-70020)
1968 Chevy C10: 4x4 conversion, 6" lift, 37" GoodYear Military OZ's, carb'd GMPP RamJet 350, Be Cool aluminum radiator, Flex-o-Lite electric fans, March accessory brackets, T350 trans, NP205, 4 wheel disc, fuel cell... etc. |
Fast EZ EFI
You could also just get an intake, throttle body, ECM, and wire harness from a salvage yard. Nelson Performance makes a wiring harness made to adapt to older vehicles.
Still Just Havin Some Fun!
![]() Join Date: Jun 2007
I have an extra intake with rails and a DBW TB if you want to do some swapping.. I don't have the harness. However, several companies make them to spec.
a green one with some stuff done to it.... |
I wasnt really considering the carb replacement efi systems... would rather go with something closer to factory.
I was originally looking to do an entire 6.0 with harness swap but in all honesty I was a bit overwhelmed with the wiring portion. Could of had something to do with the fact that I replaced the entire chassis harness at the same time of the motor swap. One more thing to troubleshoot might have sent me over the edge! Plus i came across a good deal on my lq4 that had a bit of fire damage and melted the intake. Any ideas on how much that Nelson Performance harness would run me? Would still need an ecu i'm assuming? Seems a shame to ditch it ![]() |
