Old 04-20-2011, 11:43 PM   #1
'87shorty
whats a good cam?
whats a good cam for a 92 burban 350 block converted to carb. im looking for a cam that i can run the stock drivetrain on it. also how do you go from stock rockers to roller rockers? and whats the difference between roller rockers
'87shorty is offline   Reply With Quote
Old 04-21-2011, 02:09 AM   #2
dmartin1
dmartin1's Avatar
Re: whats a good cam?
im guessing it would be hard to just name a good cam for your engine,seeing as there millions of different sopecs in every cam out there.
what you should get is considered an RV cam.mild,able to run on stock springs etc.
i cant say a lift and duration etc.
brand depends on $ ya wanna spend.
if you wanna spend 300-400$ get a comp cam
if ya want cheap go to PAW automotive or ebay.
all i could say to help.i tried:
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 04-21-2011, 02:25 AM   #3
'87shorty
lol thanks for the advice...
Old 04-21-2011, 06:32 AM   #4
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I recently put a Comp Cam "high energy" cam (260 dur.), I actualy gain'd more than 3mpg on the highway. smooth idle, compatable with stock drive train, even on my TBI. decent price. check with Jeg's or Summit.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 04-21-2011, 01:39 PM   #5
'87shorty
Which cam is it? do you have the item number cause summitracing has several posted...
Old 04-22-2011, 12:44 AM   #6
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Jeg's # is 249-12-206-2.
'85 1/2 ton CCSB
'92 S10 350/350
Old 04-21-2011, 07:40 AM   #7
BigBlocksRule
Roller rockers aren't going to pick up any performance, particuarly in a stock-ish engine. Spend that money on headers instead. A 214/221 or 221/228 cam will work nicely, just make sure you have the correct valve springs to handle it.
BigBlocksRule is offline   Reply With Quote
Old 04-21-2011, 01:40 PM   #8
'87shorty
how do i make sure i have the correct valve springs???
Old 04-21-2011, 01:56 PM   #9
PRattenbury
I'm swapping from an Edelbrock Performer cam to a Comp Cams XE-268. I'm also going to roller rockers. You don't need to do anything special to go to roller rockers. I have screw in studs, guide plates, and girdle. But honestly you can just put roller rockers on your stock press-in studs. You will likely need tall valve covers. As cams go, they say the cam I am installing is about as lopey as you want to go and still use the stock torque converter. I've had some really big cams in street cars. They might sound awesome, but they don't go worth a flip. No lower end power. No manifold vacuum for minor accessories like power brakes...Really not a smart choice for a street machine. I think the duration should stay at 280 or less, and the advertised lift should be .480 or less for decent street manners.
PRattenbury is offline   Reply With Quote
Old 04-21-2011, 05:27 PM   #10
f.monroe
f.monroe's Avatar
Have you already purchased the XE268 cam, lifters,springs?
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 04-21-2011, 05:34 PM   #11
PRattenbury
I have had the cam new in the box for a few months. Kinda came as part of a package deal with a 350 4 bolt main motor. I just ordered the lifeters and roller rockers a few days ago. I was expecting them to show up today. I paid 45 extra bucks so they would. The day aint over yet...
Old 04-21-2011, 10:05 PM   #12
'87shorty
how much did you end up spending on everything???
Old 04-22-2011, 08:39 AM   #13
PRattenbury
For the valve train stuff (push rods, roller rockers, studs, guide plates and girdles) it was 550 bucks. Adding the lifters makes it 640.
Old 04-21-2011, 10:10 PM   #14
85Bowtie
85Bowtie's Avatar
Rhoads Lifters will help fix that....
I think the Voodoo 256 or 262 would be a better choice than the XE268 for a "stock" engine. I'm running the XE268 in a Chrysler 383 with a 2500 stall and 3.23 gears, I couldn't imagine a stock 350 with a stock converter and stock gears running this cam effectively.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 04-21-2011, 10:17 PM   #15
baclay9
My dad had a xe268 in his mild BBC when he got it. I don't know how the sound would differ in a small block but it had a nice sound. Just enough lope so that you new it was cammed but nothing big. I thought it had really good street manners.
baclay9 is offline   Reply With Quote
Old 04-21-2011, 11:17 PM   #16
'87shorty
what are the power gains, fuel gain/loss, with the xe268 cam
Old 04-21-2011, 11:50 PM   #17
85Bowtie
85Bowtie's Avatar
You're going to need alot more than a 268 cam to move that Suburban. The 268 cam with stock everything will make it a dog. You want low end torque. A BBC and a SBC react totally different to that cam, especially a BBC with a 4" stroke...
Old 04-22-2011, 12:59 AM   #18
Altec
Getcha Pull
Altec's Avatar
Explain...
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 04-22-2011, 08:48 AM   #19
PRattenbury
I think he is agreeing with what I said about too much duration and lift taking away from low-RPM power. The 'bigger' the cam, the higher your power band moves up the RPM scale. And the less manifold vacuum you will have at idle. If you have to have a big rumpity cam for some odd reason (drag racing comes to mind), you would be well advised to add a stall torque converter to your shopping list that will let your transmission effectively slip until the RPMs get higher. Not to mention, other ingredients in your engine would also likely change. Like your intake manifold you would likely want a single plane versus dual. It depends what your intended use of your vehicle is for how you build your engine and drivetrain. I hope the XE-268 cam isn't too nasty because my intended use does not include drag racing. More like occasional commuting.
Old 04-22-2011, 11:13 AM   #20
jrcaprai
An EX268 Cam is Pretty Mild actually, I had an XE284 in a 383 with Stock 882 Heads, edelbrock performer and an edelbrock 600 CFM, and a 2400 RPM Converter... and 3.08 Gears....the thing had really good torque and mid-range, then dropped off quickly after 5200 RPM due to the Heads.... granted it only had 10 " of vacuum.
IMHO, I think you will be really happy with that cam, especially if you add an Edel Performer RPM intake and you will probably get about 15 " of vacuum... Plenty for Brakes
Single planes really aren't very effective until you get into the upper RPM's such as above 6000 RPM.... an Air-gap will beat the tar out of a Single plane until about 5500 RPM's
jrcaprai is offline   Reply With Quote
Old 04-22-2011, 05:13 PM   #21
slugish
Slugish
what is the lift & duration on a xe 268 cam ? Think thats what I have > mild lope , more choppy just enough to know its not stock . Real pleased with the performance of it . Ithink I would need better flowing heads if I got a larger cam .
slugish is offline   Reply With Quote
