04-22-2011, 02:02 AM | #1 |
frames
i have a 68 shortbed fleetside 1/2 ton, i believe the frame is tweaked...will a 1968 body bolt right up to a 1965 shortwheel frame? what mods would need to be done?
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks ) 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ) 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ) |
04-22-2011, 08:41 PM | #2 |
Re: frames
helloooo, nobody knows??????.....WOW
04-22-2011, 08:55 PM | #3 |
Re: frames
Are you sure it is tweaked? The front part of a bare frame (no frontend) looks bent on all the frames.
72 Cheyenne Super 80 Silverado Blazer 2wd |
04-22-2011, 10:31 PM | #4 |
Re: frames
To bad you not closer ,we could put it on my frame machine and fixer up. Most any collision shop with frame repair capabilities could fix your troubles. Most will have a min. charge for set up [that takes the longest] Once tied down a pull should be really quick. No body shop[almost ] will let you hang out and watch a pull on their machines cause they don't want you to know how quick it goes. Jim
04-22-2011, 10:54 PM | #5 | |
Re: frames
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks ) 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ) 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ) Last edited by mexgrhd68; 04-22-2011 at 10:55 PM. |
04-23-2011, 02:35 AM | #6 |
Re: frames
ouch... that strinks... think it would be cool to watch
"Feel it's not a bonfire unless they can see it from space?" ~ Capt. Morgan 1970 Cst - 20 402 1984 Chevy C30 6.2L Diesel crew cab Dualie |
04-22-2011, 10:51 PM | #7 |
Re: frames
well, i installed tie rod ends and had to cut about an inch on both inner and outer on right side...when it got hit last year, i didnt think it wouldve done that much damage, didnt really get hit hard......but, i guess it did..
04-23-2011, 10:15 AM | #8 |
Restoration Virgin!
Re: frames
couple things....I know my frame was tweaked, but didn't get it taken care of till I had almost gotten done with the project...cost me $300...
I'm not sure things will bolt right up on the 60-66 frames, plus the mods may cost you more $$$....but if yours is really bad, and you don't want to spend the money to get it pulled out, check your local CL....you maybe able to find a good frame (maybe??) cheaper
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-23-2011, 11:43 AM | #9 |
Junior Member
Re: frames
It can be done, but will require installing mounts in differnent places and the frame horns on the front are different.
My son put a 63 body on a 69 frame and had to move cab mounts and cut the frame horn ends and switch them.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-24-2011, 01:14 AM | #10 |
Re: frames
do u have to move mounts around farther from existing points, or are they pretty close? are the mounts also different as compared to the 68?
