Old 04-22-2011, 11:05 PM   #1
shiner2001
shiner2001's Avatar
Any help finding a vacuum switch from an 81-83'ish model??
I normally post over in the 67-72 forum, but have a question for you guys here. In my 64 El Camino, I have a 700r4 that I just had rebuilt and beefed up. This car is heavily cammed and according to my mechanic that did the trans rebuild, the heavy cam and torque converter aren't playing too well together. He says this can be fixed by adding a vacuum switch from what he said was about an 81-83 model Chevy truck. According to him, it's located under the hood on the firewall, just to the left of the steering shaft and brake booster (where you'll find a wiper motor on lots of vehicles from what I gather). He says this switch will have a vacuum line from the manifold on one side and a two wire connection on the other. Can anyone here shed some light on where I might be able to track this switch down? Mechanic says it will be a junkyard find, but I'd sure like to find a new one if possible. And if anyone can give me specifics on the part number/name/years/applications of the switch, that would be a big help if I need to head to the the pick-n-pull.
Thanks in advance guys, I appreciate it!!
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 04-23-2011, 08:23 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Any help finding a vacuum switch from an 81-83'ish model??
you could try LMC or try the dealer but i too think thats more of a junkyard find too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 04-23-2011, 11:54 AM   #3
shiner2001
shiner2001's Avatar
I gave LMC a check when I got home from the shop yesterday, but I didn't turn up anything. If there is any way someone can post a picture or two of this switch (installed and/or removed), that would also help tremendously! Thanks again guys!
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 04-24-2011, 06:05 AM   #4
D13
D13's Avatar
That switch controlls the TCC apply of a 350C based on vacuum. Others that have used it have been unsatisfied with the behavior of it (still have a lot of TCC hunting). With a big cam and no vacuum it's just going to make you annoyed, everytime you touch the throttle it'll unlock.
A description of what you don't like about the trans behavior will help. Remember, on a 700R4, vacuum has nothing to do with it's shifting or tcc. If you want to delay TCC or only have it applied at cruising speeds there are ways to do that. Like a 35mph governer switch in the trans. Or a 4th gear only switch, a TH400 kick dow wired as an interrupter....
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 04-24-2011, 06:53 AM   #5
sumran
sumran's Avatar
Check here.
http://www.bowtief.overdrives.com/index.shtml
I would talk with Steve. He is very helpful and knows his stuf
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 04-25-2011, 12:52 AM   #6
shiner2001
shiner2001's Avatar
On the 30 minute drive home from the shop I was honestly not unsatisfied with the transmission's performance. My mechanic's point of view is that it would drive more favorably with the vacuum switch installed, but maybe it comes down to personal preference. I haven't driven the car enough to really experience all the ups and downs, I was just going off of what he said. As far as I'm concerned, automatic transmissions operate off of voodoo and voodoo alone. That's the one part of a car or truck that I won't dive into head first, and my knowledge of how they work and what is preferable as far as options is reflected thusly.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
