04-23-2011, 04:30 PM | #1 |
Panoramic Change
I would like to send a big thank you out to John Gilbert, Steve Bentley, and CCT for their tremendous window conversion article in the May 2011 Issue. I also want to thank all you Classic Truck Guys for your positive comments and genuine interest. Scott Hursh
04-23-2011, 05:24 PM | #2 |
Re: Panoramic Change
I was wondering if it was possible to make the small to big window conversion without changing the inside sheet metal. I think they made it look easier than it would really be. All I can say is you better have you cut template lined up pretty darn good before you cut.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
04-23-2011, 06:11 PM | #3 |
Hi Rich, What I have found is that the inner cab metal behind the jamb at the lowest part of the window on the factory big window swoops deeper into the corner so you need a fill panel to reach the slightly larger radius of existing inner cab. Scott
04-23-2011, 06:19 PM | #4 |
1961 crewcab
nice article.. interesting that you can either weld the outside seam and finish, or as they did just leave it with a flush gap.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
04-23-2011, 06:20 PM | #5 |
Happy to be here
Welcome to the forum Classicbigwindow. Looks like you offer a very desirable conversion kit for the 60-66 trucks. If you have any interest in becoming a Forum Vendor, please let me know.
04-23-2011, 06:38 PM | #6 |
Thanks, John had mentioned that the next issue will show more progress and maybe glass install.
04-26-2011, 09:26 AM | #7 |
Next month's CCT does have part II. We held off putting the glass back in until after I took care of some surface rust and re-caulked the drip rails. I finished up with semi-gloss white paint on the roof. Now the windshield is back out and I'm painting the interior of the cab including the dash.
That story won't be in until after I've done a story on installing rack & pinion steering with a fast steering ratio. And thanks again Scott, you do a real nice job of hand-forming the inner panel to convert to a BBW. |
04-26-2011, 09:42 AM | #8 |
I would really like to do this conversion, but $ and skill have kept me from it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
