Old 04-25-2011, 12:51 PM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Driveshaft time
So I have NEVER done anything with a driveshaft in my automotive life. I can replace a u-joint fine, but have never measured for or really worked with a drive shaft.
The truck is my 66 short bed step side.
Old setup WAS 355 w/700r4 to 12 bolt
NEW setup IS lq4 w/4l80e to 12 bolt.
I thought I might be able to have the existing shaft modified to fit, but its actually too short, not too long. How do I know what ends I need, and how to measure for the shaft? I have read a few different instructions but it seems like the measurements I get, don't really make sense against what I'm reading.
Any help? Pics would be great.
Also, do I need to buy a seperate yoke for the trans? or does it come on the new shaft?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-25-2011, 01:08 PM   #2
Clyde65
Clyde65's Avatar
Re: Driveshaft time
If you have a reputable driveline shop in your area, you can call them and tell them what trans you have, and measure from center of rear u-joint to the end of the tranny tailshaft, they will make you one and balance it
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-25-2011, 09:16 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Driveshaft time
I bookmarked this back in 07 when I started researching a LS swap.
http://www.automedia.com/Building_a_...es20040301ds/1
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-26-2011, 04:41 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Driveshaft time
good info, strangely, the man measuring the shaft looking Amish.
Old 04-26-2011, 07:39 PM   #5
TR65
TR65's Avatar
Re: Driveshaft time
This is the Dana-Spicer u-joint catalog. Look under conversion u-joint kits if you want to adapt a particular drive shaft to another transmission or differential.
http://www2.dana.com/pdf/K350-1-DSSP.pdf
It takes a little head scratchin but it is all in there.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 04-26-2011, 08:09 PM   #6
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: Driveshaft time
http://www.dynotechengineering.com/
They have made a couple of shafts for me. Fast service and the will help you decide what you need for your application. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 04-27-2011, 05:40 AM   #7
67C10BUB
67C10BUB's Avatar
Re: Driveshaft time
This is where I got mine done. I think it was around $250 for them to shorten it, install a new 27 spline slip shaft, and all new U-joints.http://www.iedls.com/Driveshafts/Mea...riveshafts.asp
67 5.3L Build
67C10BUB is offline   Reply With Quote
