04-25-2011, 02:19 PM | #1 |
Later model rear AC
I recently acquired a rear AC out of an 87 burb......It's not a direct bolt-in, but with careful placement, it looks like it was made for a three door and doesn't obstruct the back window.
Here's pics: Last edited by AzDon; 04-25-2011 at 02:29 PM. |
04-25-2011, 02:32 PM | #2 |
Re: Later model rear AC
Couple more pics:
04-25-2011, 10:25 PM | #3 |
Devil's in the Details
That looks great. I was just eyeballing a rear unit from a mid seventies burb myself about a week ago. Nice to know that it looks to fit so well.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
04-25-2011, 11:21 PM | #4 |
Looks like a good fit. Nice work!
Doug '72 GMC K2500 Suburban 4x4 |
04-26-2011, 12:30 AM | #5 |
The 73-87 burbs must be slightly more bulbous in the roof down to the back window, because there is a .75" gap across the back for which some kind of filler piece could be made (if it matters)
When scavenging one of these units, be careful because the evaporator (black) housing is fragile and can require extensive repair (mine did). The evaporator housing was obviously designed originally as an under-dash unit! I had a 74 burb with this setup, and you could feel the cold air on the back of your neck while driving! |
04-26-2011, 05:47 PM | #6 |
that looks nice. Ive been looking into one of those but my only problem is i have a custom 1 piece fiberglass headliner so im goint o have to work around that. good job though!
04-26-2011, 09:45 PM | #7 |
its all about the +6 inches
nice, it hangs down less than a 72 rear A/C unit does. Doesn't the 73 - 87 unit have heat too?
04-28-2011, 01:04 AM | #8 |
We see a lot of rear AC units in AZ, but I've never seen one with heat. It would hafta be different internally than any i've seen in order to accept the add-on of a heater core. It's hot down here, so we dont worry much about heat!
04-29-2011, 06:48 PM | #9 |
I think I remember reading that they had a heating element in there, like in a toaster. It could have been later models or I could be remembering something wrong.
05-21-2011, 12:34 AM | #10 |
