Old 04-26-2011, 09:57 AM   #1
68 lover
will 3/5 CPP drop kit work for me?
Can anyone tell me if aCPP 3/5 drop kit will work on a 1968 without doing any other modifications? What about C notch I keep hearing about? Truck has front disc and rear drum. thanks
68 lover is offline   Reply With Quote
Old 04-26-2011, 10:00 AM   #2
19seventeeCustom
Re: will 3/5 CPP drop kit work for me?
kit should work just fine, no c-notch needed with a 5" drop. There are a lot of members running that same exact drop with no problems.
19seventeeCustom is offline   Reply With Quote
Old 04-26-2011, 10:12 AM   #3
OJ1988
Just a car guy
OJ1988's Avatar
I recently installed the 3" front, replacing my cut stockers. It actually raised mine some. It looks low and is almost touching the bumpstops on my lower a arms, which are off a 1975.
I am probably going to cut 1/2 coil off these to get the look I want.
Got to see the rears first.
I am in the process of swapping the 5" into the rear on mine as well. Replacing stockers that I assume were heated.
Looks like it will sit about the same in rear, which makes me think I may add a 1" block.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 04-26-2011, 10:20 AM   #4
OJ1988
Just a car guy
OJ1988's Avatar
Edit! This is with stock cut fronts and heated rears. Stock 235/75/15 tires
1973 Vega Drag Car
1970 C20 tow rig
Old 04-26-2011, 10:22 AM   #5
OJ1988
Just a car guy
OJ1988's Avatar
With 3" ccp fronts and stock heated rears, With 235/60/17s
1973 Vega Drag Car
1970 C20 tow rig
Old 04-26-2011, 10:58 AM   #6
leddzepp
Moderator
leddzepp's Avatar
you will not need a c-notch with a cpp 5" rear drop spring. i have cpp 5" rear springs, along with 1.5" blocks. i just finished installing a c-notch in mine, as it was needed at that point. you will have about 3" of clearance running just the drop springs. you will need to remove the factory bumpstops.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-27-2011, 01:16 PM   #7
67chevemall
67chevemall's Avatar
ya the back is easy..no C notch is needed unless you want the frame on the ground........the front gets to be a headache with the drop spindle that has to have the disc brake upgrade. you can cut the spring down and run it...i did this for years but it wears out the outter inche of the tire.... If you want to put airbags you have to put in the 2.5 drop spindle and disc brakes....and then the stock rims don't fit so you need to get 18's or 20's.....seems to never end. Do it right the first time....get the front disc brake kit, and ball joints, tie rod ends if you need new ones....the 2.5 drop spindle, the rev 7 air bag kit from SDoors, and 20 inche rims....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
