Roto Reuter thats the name...
![]() Join Date: Feb 2010
Think my horn is toast. What horn(s) were used on these trucks?
I think my horn is shot on my '69 C20. It sounded horrible then stopped working. I removed the horn and bench tested it with my battery charger and it beeped once and that was it. Does nothing. I don't have my steering wheel installed, but when I complete the circuit by touching the horn wire to the column I can hear the relay clicking. So I plugged a 12V test light into the horn wire in the engine compartment and it gets power when I touch the horn wire to the column. Does this make sense that it would be the horn?
What horn or horns were installed on these trucks? Were they a single horn or double horn set up? I only had one horn and one wire. The horn appeared to be an aftermarket horn. Where can I get a replacement horn set up if this is indeed the problem? Not sure if this is the right location for posting this thread.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
its all about the +6 inches
Re: Think my horn is toast. What horn(s) were used on these trucks?
personally, I'd go to a junk yard. For 5 or 10 bucks you can get 2 horns, a high and a low, off the same car and have a great sounding horn on your truck. A single tone always sounded chintzy to me, but a bi tone, or even tri tone sounds classy.
Or, you could run to napa and get a horn or two and splice the wire to make there universal (read, fits nothing) set up in place... but those don't last long... couple years and they crap out (I blame china) and you get to do it all again. |
Was the two-horn system standard? What would I look for in a junk yard to get this out of? Seems like it would be better. How is it wired? I have aftermarket wiring harness with only one wire. Would I need another wire or just tap another wire off the one?
20' Daredevil (Ret)
![]() Join Date: May 2003
My truck came with two horns, but you say yours has just one wire. No worries, easy enough to extend a wire to a second horn. I agree with Andy, go to a boneyard. I'd look for any late-model full-size GM truck or car -- they should have good powerful hi/low horns.
The green wire sends 12vdc from the horn relay (under the dash) to the horns, which are mechanically grounded to the core support. So it's important to make sure the core support is properly grounded.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
"THE GREEN GOBLIN"
The wire Harness only has one green wire that goes to the green horn wire there is another green wire its like a jumper wire then you plug that end to the other horn. something like that sorry if I make it sound confusing. I would take a picture for you but im at work. Let me know if you would like a picture and I can take one later tomorry and post it for you. You might be missing the Jumper wire it is also green.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 04-27-2011 at 03:43 AM. |
#6 | |
20' Daredevil (Ret)
The single horn that came on the truck was a cheap aftermarket one. You're right Longhorn Man... China. I think I'll take you up on the boneyard idea and look for a high/low horn set up. How would I wire that though? Stocker's pict shows the green wire going into the first horn and then out to the second horn. Doesn't the horn have to have a ground wire to chassis? Is it ok to run the green wire in/out of the first horn and then run only one ground wire on the second horn to the chassis? Or do you tap off of the green wire and run one to each horn and then run chassis grounds on each?
fat old dude
i have an old ahooga(sp?) horn and the stock horns.
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
Got it! Thanks Stocker.
try spraying wd40 into the horn to clean up 40 years of dust and crap off the vibrating diaphram to allow for better louder clearer operation // as stated clean the mounting surface real good to allow for good ground and do not overlook making sure you've got a good ground connection between the core support and the frame rail
I could do this on the one I have except its a cheap aftermarket piece of junk. When I pick up a hi/low one from the boneyard I'll keep this in mind.
Would you believe I checked a couple of junk yards and no one has older GM hi/low horns. The ones they do have don't work. Thought for sure I would be able to find some. So if anyone has any insight on where I could get a working two horn set up for my '69 C20 let me know.
