Spindles
If I replace the original spindles with 2.5 drop spindles, Will I have to go with different top & bottom ball joints? I bought some new stock ball joints from the auto parts store and the pin holes won't line up with the nut. Here is a pic of the bottom ball joint. Not a very good pic.Thanks in advance... Dave
#2 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Spindles
What year ball joints did you buy? The aftermarket spindle companies (Belltech, McGaughy's, CPP, POL, Western, etc) make year specific spindles so you don't have to change anything. They break down as follows: 60-62 63-70 71-72 73-87
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-27-2011 at 10:11 AM. |
Local Redneck Authority
Re: Spindles
Not to hijack the thread but is there a breakdown on a arms? I read a lot about using the 73-87 suspension including crossmember. I assume 72-73 is a breaking point but what a arms fit what spindles?
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor Last edited by propanemudtruck; 04-27-2011 at 12:59 PM. Reason: I caint spell sometimes |
Re: Spindles
All 1/2 ton and 3/4 ton upper arms are the same.
Break down: 63-72 73-87 All 1/2 lowers are the same. Breakdown: 63-72 73-87 * 3/4 ton lowers have a larger ball joint hole. * 63-72 have steel cross shaft bushings. * 73-87 have rubber cross shaft bushings. * All arms can be swapped between the (63-72) crossmembers and the (73-87) crossmembers. * 73-87 lower a-arms use a slightly bigger u-bolt to mount them. (easily fixed with a drill)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-27-2011 at 01:30 PM. |
Re: Spindles
What other years. Will fit a 87 silverado ... seen other drop spindels for sell just don't know if they will fit...
Posted via Mobile Device |
Re: Spindles
73-87 spindles will fit your 87.
