![]() Join Date: Apr 2011
Replacing upper and lower ball joints
While I'm doing the front brakes on my '65 chevy truck, I'm going to replace the upper and lower ball joints. The rubber on both is split. It appears the upper joint is held in with rivets. I figured I would grind them off flush with the top of the joint and then, drive the rest of it thru. Not shure how the lower ball joint is secured. Is it a press only fit? I don't see a retaining clip any where. Any advice or tips would be greatly appreciated. Did a search on the site and didn't really see much. Thanks in advance.
edit: I checked you tube and there were videos but, for some reason they wouldn't play Spanky Last edited by '65 chevy lover; 04-27-2011 at 10:01 PM. |
Re: Replacing upper and lower ball joints
When I did mine a little while back, I believe the lower ball joints were just press fit. The tops I used an air chisel to pop the heads of the rivets and then punched out the rest of it. The new upper ball joints should have bolts that replace the rivets. I don't know if this helps.
p.s. - wear ear protection if you have your head inside the fender well while you are hammering, grinding, or chiseling. I remember my ears hurting quite a bit after air chiseling with my head inside there. Probably wasn't the smartest idea ![]()
Jeremy 1965 Chevy c10 Short Stepside Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=410658 |
#3 | |
Yeah, that helps alot...I guess you use a pickle fork to get the lowers out...is that right? Thanks, Spanky |
It wasn't a pickle fork, but that probably will work. I believed we used some kind of ball joint puller that was powered by an impact wrench. And I'm pretty sure we used the same tool reversed to get the lower ball joint back in. That was in my highschool shop class, so I don't remember what the tool was called.
Jeremy 1965 Chevy c10 Short Stepside Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=410658 Last edited by LiLDrumKing3; 04-28-2011 at 06:39 PM. |
![]() Join Date: Dec 2010
You can rent a ball joint press from your local AP store, makes the lowers a snap
I got the tops of the rivets ground off but, I'm having a hell
![]() Thanks, Spanky |
+1 on what drum king said. grind rivets off and the new ball joints come with bolts. i used a BFH to get the lowers out then used a big socket and a hammer to get the new ones in. i also had the lower control arms off the truck too.
The price of cool aint cheap. |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
There's talk that upper and lower ball joints are expensive for the 60-62.
Why couldn't we just replace our ball joints with newer model ball joints?
As said above, the parts stores (O'Reillys) will "loan" you a ball joint press, just leave a deposit.
The lowers press in and out, USE THE TOOL!
292 + TKO500 |
