Old 04-28-2011, 07:44 PM   #1
K10Dream69
K10Dream69's Avatar
Question Vent window. very frustrated need advice.
so I went to pick n pull and mange to find a GMC and the vent windows weren't pitted and in really great shape. so after pulling them out I ordered new weather stripping for them. after reading on all the threads with tips on how to go about doing this. I know I don't have to stress how time consuming this whole process is. I ordered a vent window rivet kit off ebay from Grumpy's truck parts with 'flaring' tool for $18. Kit might have been worth $1.80 if that.
So I finally get the new weather stripping on and rivetted on the other channel. After trying to use this amazing rivet kit I noticed that it just split it more then 'flared' it, I finally get to the point where Its just about snug the arm/bracket that attaches to the vent window breaks. I already have about 3-4 hours into this PITA and now this happens.
Is it possible to weld this back together or am I pretty much screwed? Any advice is appreciated.
K10Dream69 is offline   Reply With Quote
Old 04-28-2011, 08:07 PM   #2
gkesseru
gkesseru's Avatar
Re: Vent window. very frustrated need advice.
Cant help your break, but as far as riveting: I used a stainless 4-40 panhead with a locknut on both of mine. This way I can adjust the tightness.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 04-28-2011, 08:13 PM   #3
mbgmike
I know how you feel. We used to offer a rebuilding service for those but even with a high $$ hydraulic reviter and the parts cost and shipping, and time it takes it just was not a real money maker.
The revits are around $1.00 each( we sell them) and that tool is not worth much. If you use that tool you have to start the flare with a beveled punch to get it rolled over and then round it over using the tool you bought. We sell a better one but it costs too much for just one use. they just split or are lopsided if not careful. We won't even use that. You can do a better job with punches.
You can weld the tab back on. Last ones we had re-chromed were around $35.00 to $40.00 each. Might be less work to find another used one here, then to fix that one. SOme guys use a pop revit on the inside rather than mess with the pivot revit.
mbgmike is offline   Reply With Quote
Old 04-28-2011, 08:14 PM   #4
leddzepp
Moderator
leddzepp's Avatar
I used pop rivets, no fuss, no problems. That tool is a joke. IIRC MBGMike has the correct tool that will press and flatten the traditional style rivets.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-03-2011, 11:32 AM   #5
K10Dream69
K10Dream69's Avatar
Thanks for all of your input. I used plain pop rivets on the channel instead of the tool and those worked great. On a positve note I managed to get that piece welded back together. So I get another chance at a fresh start at it.
Does the vent window still swivel easily with using pop rivets or is it really tight? That'd make it a whole lot easier if that's the case!
