1957 4x4
Re: 1957 4x4
That is sick!!! Awesome truck. Give us some details, specs!!
Re: 1957 4x4
Thank you. It has a ZZ4 create motor, th-400, Dana 60 up front and a corporate 14 in rear. Crossover steering. I drives great...a little rough but thats half the fun.
Re: 1957 4x4
Anyone use a disc brake conversion for a Corporate 14. Just looking for any pitfalls.
Re: 1957 4x4
Put a conversion kit on my 71. Absolutely no problems or pitfalls. Same Truck, same axle: now and before.
![]() ![]() Last edited by lukefalls; 05-05-2011 at 11:45 PM. |
#6 | |
God is good!
Re: 1957 4x4
I don't want to lose my emergency brake and as far as I know, that's the only way to keep it. I have seen some other new calipers with the built-in ebrake on Speedway, but I'm not sure if they will work. If you don't "need" the e-brake or need it to pass inspection, then the conversion is the way to go. There are a whole lot of how-to's all over the 'net that show you how to do the conversion. Killer truck, by the way.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
Re: 1957 4x4
High Angle Driveline makes an E-Brake kit that mounts on the driveline. It is a bit expensive, but works better than the El Dorado calipers.
http://www.highangledriveline.com/e_brake.html Also, I believe that Pirate4x4 has a "14 Bolt Bible" that has wheel stud info. I think that it gives part numbers to different size studs that will work in 14 bolts. |
Custom Builder
![]() Join Date: Jun 2003
Re: 1957 4x4
Killer Truck!!!
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
Re: 1957 4x4
wow!! just wow!
1990 k5 blazer 1990 gmc jimmy 1949 1300 p/u-sold 1977 bbc skylark 96 roadmaster 06 9c1 impala |
Re: 1957 4x4
Now that is COOL!
Re: 1957 4x4
Wow. That thing is a beauty.
Local Redneck Authority
Re: 1957 4x4
no flippin way! That's a sweet truck!
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
Re: 1957 4x4
Thanks for the comments.
![]() Join Date: Jul 2009
Re: 1957 4x4
Un friggin believeable. Love the black rims against the green with the older truck. Your attention to detail is unbelieveable. Well done!
I am trying to do something similar with my 71 4x4 using 20" KMC Diesel rims. Assuming you used stock axles, how did you get your wheel studs to handle the aftermarket rims? When I went to mount my rims on the OEM wheel studs I found the studs to be about an inch too short due to the extreme hub thickness of my Diesel rims. |
#15 | |
Re: 1957 4x4
#16 |
Re: 1957 4x4
Fn AWSOME thats all that can be said !!!!!!!!!!!!!!
2004 Silverado Crewcab (Dark Spiral Gray) |
#17 |
Boss Hogg
![]() Join Date: Apr 2002
Re: 1957 4x4
#18 |
Boss Hogg
Re: 1957 4x4
Build thread???
I wanna see more!!! ![]() ![]() |
#19 |
#20 |
Re: 1957 4x4
That's awesome!
I've had a 59 1 ton since 79. put the running gear off a 73 3/4 ton 4x4 suburban under her in 98. North of 750,000 miles. I've done construction from Austin to Fairbanks. I'm nearing retirement and I'm ready to start taking her to the next level for off road camping. Do you mind questions? |
#21 |
![]() Join Date: Feb 2004
Re: 1957 4x4
That is an awsome truck.
I would leave the drums as they work fine and have a very good e-brake. Spend the money on a fitech or such. On the 67 I have disc on my 14 bolt (9.5) with Camaro calipers. All work fine except not an e-brake anymore and barely a parking brake. I like 4 wheelers.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 08-15-2020 at 04:03 PM. Reason: words |
#22 | |
Re: 1957 4x4
His last post was November 2012
![]() Quote:
#23 |
Re: 1957 4x4
Same truck though!
Engine's out, front clip is off and we're finally working on it again!
59 Apache 3805 (1 ton Panel) Stroked 350, SM465, NP-205 Corporation 14 behind Dana 60 |
