Old 05-05-2011, 12:22 PM   #1
rightwingdave1
275/60/15 on a 1961 Chev Stepside?
Hi;
Will Goodyear Eagle St 275/60/15 tires work, front and rear, on a 1961 Chevy Stepside? What about a Fleetside?
I plan on running them on AR wagon wheels.
Dave Martin
Riverside CA
rightwingdave1 is offline   Reply With Quote
Old 05-05-2011, 01:57 PM   #2
chainsaw
chainsaw's Avatar
Re: 275/60/15 on a 1961 Chev Stepside?
I have 245/60/15 on my 65 stepside front and rear. It is bagged but doesnt lay frame, tires just barely clear outside fender lip in the rear with a 15 x 8 inch wheel. Its got plenty of clearance in front. Dosent really answer your question but might help.
chainsaw is offline   Reply With Quote
Old 05-05-2011, 02:11 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
A lot will depend on the ride height, rim width and offset. I’m running 255/70-15’s on the back of my step side with 8” rims and the clearance is fine. Then again I’m running nearly stock suspension height. 275/60 is a bunch bigger. Hopefully someone that is running that size will jump in. I do believe the fleet side beds have an extra inch or so clearance compared to the stepside fenders, since they were designed for the 60 cab while the step sides were designed for the narrow (by comparison) 55 cab.
Old 05-05-2011, 03:45 PM   #4
Slow Build
Slow Build's Avatar
I'm running 275/60/15's on 8" 6 lug rally wheals all the way around with no rubbing. I have about a 4-6 drop but take into consideration that I still have drum brakes up front with stock spindles. All drop spindles will move the front wheels out from approximately .25" (CPP Modular) to .75" (others).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 05-05-2011, 05:05 PM   #5
forestb
forestb's Avatar
On my 62 stepside I used to have P275/60R15 with 15X7 wheels all the way around with a 4 inch drop all the way around and they fit fine even with the drop spindles. If you go with a six inch drop or lower in the rear you will be getting vary close to the fender even if you roll the lip of the fender.
forestb is offline   Reply With Quote
Old 05-05-2011, 05:58 PM   #6
TopFuel1966
TopFuel1966's Avatar
I don't know about a Stepside but this is a 275-60-15 on the rear of a Fleetside with 10" wheels and 4"springs. Clearance with an untrimmed fender lip is about 3/8". I do have to allow the rear end to hang to get them on and off.
TopFuel1966 is offline   Reply With Quote
Old 05-05-2011, 05:59 PM   #7
Real_McCoy
Real_McCoy's Avatar
I have P275/60/15s on the back of both my trucks (2 66 LWB C10s stock height). 2 are on 8" rims. 2 are on 10" rims. The 8" seem to have sufficient clearance on front and back. The 10" rims are really tight on the back and I have never put them up front. I will try to post pics later today.
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline   Reply With Quote
Old 05-05-2011, 09:54 PM   #8
rightwingdave1
Wow, SlowBuild, nice truck.
Hey guys, thanks for all of the input. I'm going to go ahead with it.
Thanks Again.
Dave Martin
Riverside, CA
Old 05-05-2011, 10:48 PM   #9
Rich 5150 69
Rich 5150 69's Avatar
Alot of us here are running 275/60/15 on all four..LOL
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-06-2011, 08:37 AM   #10
lakeroadster
Originally Posted by rightwingdave1 View Post
Hi;
Dave Martin
Riverside CA
It all depends on the backspacing and width of your AR wagon wheels. That is what will make or break installation on your stepside.
Best thing to do is put the rear axle on jackstands, pull off both wheels and measure clearances from the brake drum wheel mounting surface to the fender lip and to the frame, measure wheel backspacing and width, and then do the math, and buy based on that information.
Good Luck!
lakeroadster is offline   Reply With Quote
