05-06-2011, 01:29 PM | #1 |
C10 CLUB Y QUE!
airbags question
I'm working on my trucks rear airbags. I've been planning on moving them. And having them sit on the 4link. Question is does it matter were the sit on the link. Closer or further from the axel.
Posted via Mobile Device |
05-06-2011, 01:31 PM | #2 |
Who Me?
Re: airbags question
I have done this twice. On my 65, they were half way up the trailing arms. On my 61 they are just a few inches forward of the original coil spring loction. I thought both worked well for me.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) Last edited by 61_FL_Apache; 05-06-2011 at 01:33 PM. |
05-06-2011, 01:37 PM | #3 |
Who Me?
my 65
my 61
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) Last edited by 61_FL_Apache; 05-06-2011 at 01:39 PM. |
05-06-2011, 01:39 PM | #4 |
C10 CLUB Y QUE!
Mine would be a few inches further up. Just wondering how it rides. And it came down about 3 inches lower
05-06-2011, 01:48 PM | #5 |
Who Me?
The bags have about 45psi in each and it rides like a caddy.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
05-06-2011, 02:39 PM | #6 |
C10 CLUB Y QUE!
What kind of bags are they.
05-06-2011, 02:43 PM | #7 |
Who Me?
I don't know the brand and they are not marked. They are 7" and 2500-2600# range.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) Last edited by 61_FL_Apache; 05-06-2011 at 03:19 PM. |
05-06-2011, 03:24 PM | #8 |
I would think the closer you have the springs to the rear axle would put less stress on the bushings and the trailing arms. If you are going to carry any loads I would keep them close to the axle.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
05-06-2011, 03:33 PM | #9 |
Who Me?
I would agree!! I never hauled anything in my 65 so it didnt matter. There is more of a chance to haul some gear in my 61.
The ride is good!!
05-06-2011, 03:51 PM | #10 |
Active Member
If I remeber correctly, further away from the axle gives you more travel and faster lifting, closer to the axle gives you more weight carrying capacity.
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
05-06-2011, 04:41 PM | #11 | |
Who Me?
The further away give you more leverage to squeeze the bag for a nice ride. I was worried about a stiff ride with them close, but that wasnt an issue either.
05-06-2011, 09:18 PM | #12 |
C10 CLUB Y QUE!
here are some pic of what im working with passenger side is done just need to trim it. driver side im working on tomorrow
05-06-2011, 11:31 PM | #13 |
Registered Loser
If I were you I'd use bigger bars if you're going to mount your bags to them, to prevent them from bending. I believe ***************** makes gussets you can weld to the bottom of your bars to give them some extra support.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
05-07-2011, 12:30 AM | #14 |
Hollister, CA.
Dude for sure, that is gonna bend ....
Just make up something like this: My paint skills suck, but you get the idear !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 05-07-2011 at 12:30 AM. |
05-07-2011, 09:00 AM | #15 | |
The rear curb weight for a '65 1/2 ton pickup is about 1800 lbs. That means you will need 900 lbs of force to lift one rear wheel off the ground if the air spring is located at the rear axle. Now lets say your trailing arm length is about 48 inches and you want to put the air spring in the center at 24 inches. 48 inches x 900 Lbs = 43,200 in-lbs 43,200 in-lbs / 24 inches = 1800 lbs So each air spring will need to lift 1800 lbs to lift the truck. And the related suspension components will also need to handle that much force, just to lift the rear of the truck up off the bump stops. That's without any payload. It becomes pretty obvious, pretty quick, why the air spring needs to be as close to the axle as possible in order to reduce the size of the components required to handle the loads. I wouldn't put the air spring on the 4-link simply because it wasn't designed for that. Compare your 4 link bar to a stock trailing arm. The 4 link bar needs more section height for the application you are considering. Even if you gusset the bar as ChiefRocka discussed above are the rod ends adequate to handle the side loading that results due to the air spring? Last edited by lakeroadster; 05-07-2011 at 09:16 AM. |
05-07-2011, 10:24 AM | #16 |
C10 CLUB Y QUE!
Well I'm glad I ask the question before continuing this project. Over the middle axel didn't really give me a lower stands and much of a side to side. I'm going to grind it of and place off of the cnotch. Back to.the original plan.
05-07-2011, 10:32 AM | #17 |
05-07-2011, 01:10 PM | #18 |
C10 CLUB Y QUE!
here sre a few pic of the over the side axel top plate. im not to happy about it because too close to the rim
05-07-2011, 01:32 PM | #19 |
C10 CLUB Y QUE!
Avs has a behind axel lower plate for 22 a piece. And top for the same price. Anyone bought this before?
05-08-2011, 07:50 PM | #20 |
C10 CLUB Y QUE!
would this work?
