87 1ton 2wd- Front end work
Hi Guys ,
I have been reading over the form for a while and thought well i am going to write something up ! I am stuck right now with a job were are doing in the shop, We have a 1 ton 2wd, we put all NEW control arm (uppers and lowers) plus we are putting new coil springs in to, so here is the issue we put all this new stuff in and well what is the best way to get the control arm tubes up to the sub frame to put the u-bolts on with out the spring jumping out and killing someone ? Just with the 1 ton hd springs it's not very fun to work with !! LOL ![]() Any help would be Great !!! Thanks again for your help -Nick |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: 87 1ton 2wd- Front end work
ive always on these trucks and all gm products have iinstalled springs with the LCA attached and used the weight of the truck to allow the springs to seat.. you may have to compress them slightly with a spring compressor
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
BAD BOW-Silverado XST
Happy to be here
![]() Join Date: Mar 2000
Another option is to use a transmission jack if the truck is on a lift. First install the upper arm to the crossmember, hang the spindle, and attach the lower arm to the spindle too. Set the spring in the pocket, and swing the lower arm in place. Use the tranny jack to compress the lower arm and spring until you can attach the u-bolts.
I have never done it on a 1 ton, but it will work on a 1/2 ton.
