The exhaust LMC sells, installed.
I finally got around to installing the dual heartthrob exhaust that I bought from LMC. It is this one here:
![]() Took about a day of tinkering to get the old one out and line this one up. I was impressed with the fit and alignment of the tail pipes, it turned out just how I pictured it looking. It is no where near the sound of flowmaster 40 series (I wanted something quieter) but it still has a nice grunt to it. Performance wise, it is still a 1978 3/4 ton ![]()
1994 K1500 Suburban, 5.7/4L60E |
Re: The exhaust LMC sells, installed.
What did it cost including shipping? im comparing costs to what my local muffler shop quoted me for
#4 | |
If there is room, install baffle type mufflers in before or after the glasspacks. Both mufflers work very well together at canceling out the noise. The baffle mufflers remove the low frequency and the glasspacks remove the high frequency. Posted via Mobile Device |
#5 | |
And one more pic:
Looks like it turned out nice.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
Here are some more pics:
![]() Join Date: Feb 2010
In the pictures it looks like the tail pipes are making contact with the frame rails and the bottom of the bed as they go over the rear axle. Is that just an optical conclusion?
Yeah, bit of an illusion. There is about an inch of clearance from both the frame rails and the underside of the bed. I wanted the pipes up as high as possible without rattling against anything.
I got my exhaust put in and did not realize right away the tailpipe on the right side was hitting the bottom of the bed. It made a bit of a racket.
Lookin' good. I had a Heartthrob kit for my old Camaro, that I never did get around to installing before I had to sell the car. But I was super excited to hear it, the pipe pieces were really nice, and your kit looks like the same quality from what i can tell. Hope it treats you well!
TomS. '98 S-10 Blazer 4dr 4wd - 4.3, AT, stock & '85 K-10 w/ 305, 700r4, np208, and RUST! SOLD Dec 2014 |
It looks good and appears to fit great. I'd kind of like to go one size up and find a 2.5" kit for my dually big block.
Thanks for the photos I'm in a mix between this and local installer price. How long are those mufflers?
78K & 79C Jimmys
looks good,tucks up well
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#15 |
I am in the process of installing this same exhaust on my 87 Suburban.
the exhaust bolts up great and fits good, but the exhaust hangers they sent me are different than the ones in your pics. The sent me 4 4" long straps of rubber with holes in it with a lip at the bottom??? There is nothing to attach these to under my truck. Did those hangers come with your exhaust or did you have to buy them afterwards? May just take it to a muffler shop next week to have them weld in place.
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
#16 | |
78K & 79C Jimmys
#17 |
How did cost compare to getting something done locally? Did you bring it across the border yourself?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#18 |
![]() Join Date: Jul 2000
Did it bolt right up to stock cast iron exhaust manifolds? And what type would those have been in 1978?
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#19 |
78K & 79C Jimmys
both my 78s and 79s had this type of manifold,custom bent tho,I was able to remove the heat riser too
#20 |
Mine did, bolted up just fine to the stock manifolds. My kit just came with som exhaust hangers that could not be used with my truck. Got it at the exhaust shop now getting some hangers welded.
#21 |
Looks great. Went with the Turbo mufflers off the same catalog, keeps it extra quiet.
