05-10-2011, 12:51 AM | #1 |
75' c10 rear into 69' c20 truck
guys, other than the mounts being different are the newer rears wider and if so how much? thanks.
05-11-2011, 12:14 AM | #2 |
Re: 75' c10 rear into 69' c20 truck
I am doing a swap on my 1967 GMC 3/4 ton with leafs only ( no coils ). The previous owner had installed a 14 bolt GM Corporate, I'm doing a disc/drum 5 lug conversion and full suspension swap using a 1974 chevy 1/2 ton as my donor vehicle. The only thing I had to move on the rearend was my shock mounts, I am doing a 4/6 drop. Waiting to install my shock mounts after I install the flip kit on the 1974 Chevy 1/2 ton truck 12 bolt, but the leaf springs lined right up without any issues.
05-11-2011, 12:16 AM | #3 |
I believe its 1 1/2 inches wider
05-11-2011, 12:26 AM | #4 |
A guy with a truck
Yep, 3/4" per side, assuming they're both 12 bolts...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
