![]() Join Date: Mar 2011
Original aluminum grill
Hey guys, I went to pick up a new old hood for my 66 today and happened on to an aluminum grill for 20 bucks. It has a couple of dings and dents but looks like it could be brought back to life real easy by someone that does that sort of thing. Do any of you Portland area members restore these things or can you lead me to someone that does? I posted this over on the "what did you do to your truck today" page but thought I'd try a new post here. I know I got a good deal but what is the going price for these grills nowadays?
![]() Join Date: Mar 2005
Re: Original aluminum grill
You could most of that yourself. One thing to remember is that the aluminum is relatively soft, and is usually stretched wherever it gets dented. Work out the dents slowly and lightly with a nylon hammer if you can. Try to find anything to use as a dolly that replicates the shape you're trying to get it back into. Use a wood block instead of a steel body dolly. You want to try to eliminate "donkey tracks" that occur when you smack the part with the edge of the hammer/dolly.
Those grills were clear anodized (or a process called Brite Dip) from the factory. That coating will get cloudy and pitted over time. You can either find a company that does that process (it's expensive), or if you like it shiny, have a polish shop strip the part and then buff it out. Another process I have considered is having it Jet-Hot coated, wet-sanded with 2000, then cleared. I personally like the factory anodized look over the chrome grills that you see occasionally. For $20, you did good. I've seen junky aluminum grilles out here starting at $45.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 Last edited by chevyrestoguy; 05-10-2011 at 10:02 AM. |
#3 | |
Great idea, I'm checking into that now.
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
Thanks for the help. I just might give it a try. It really isn't that bad so I might be able to pull it off even with the very little experience I have. I'm not familiar with the hot-jet....looking into it now.
60-66 Nut
If you want to try polishing that grill yourself, you will need to strip the clear anodizing first. You can do that with common spray on oven cleaner. You may need 2 or 3 applications to get it all off. Just be careful with it, it will burn your skin.
Here is an article I had saved in regards to striping anodized aluminum:
Hope that helps!How to Clean and Polish Anodized Aluminum Happy Trails....... John Last edited by lakeroadster; 05-12-2011 at 09:54 AM. |
