Old 05-10-2011, 03:16 PM   #1
taank
Welding patch panels
Having a **** ass time fixing po's welds . The patches are so thin I burn through instantly with my welder at it's lowest setting! Must have been from if Whitney or something. Since now I'm going to redo everything. Where is the best place to get a complete floor and inner and outer rockers. Better yet I should just order a fiberglass cab and be done with it.
taank is offline   Reply With Quote
Old 05-10-2011, 03:29 PM   #2
EZ4U2C
EZ4U2C's Avatar
Re: Welding patch panels
What kind of welder are you using?
God loved me so much he gave me John 3:16
Buy American and bring our jobs back home.
Trust what you believe in and believe in what you trust.
Don't blame the gun, Blame the person who made you use it!
1970 swb
2002 Harley Davidson Road King Classic
2004 Dodge 4x4
EZ4U2C is offline   Reply With Quote
Old 05-10-2011, 04:23 PM   #3
taank
Millermatic 175 230 volt. Using 75/25 gas .024 wire
Old 05-10-2011, 05:16 PM   #4
my67c20
Your setting is way too low. I have the lincoln 135 weld pak had it set at the C setting (not sure of what that is on the Miller) also the wire speed at 6.5. Layed out a nice spot everytime. Gas should be at about 15psi. Ultimatly you want high amps fast wire speed. Listen for the bacon.
my67c20 is offline   Reply With Quote
Old 05-10-2011, 06:42 PM   #5
taank
for thick metal yes. for sheet metal no. millers recc. setting is 1.5 volatge and 40 wire speed.
Old 05-10-2011, 06:58 PM   #6
lakeroadster
I am guessing the problem is the PO ground down the weld and thinned out the base metal. You are kind of screwed if that is the case.
lakeroadster is offline   Reply With Quote
Old 05-11-2011, 01:04 PM   #7
EZ4U2C
EZ4U2C's Avatar
Hey taank,
Try this, find a piece of aluminum 1/4'' thick grind the area behind where you're going to weld. Clamp if you can the aluminum if not hold it tight against the metal. Spot weld in the middle of the area let cool and work your way out. Once it cool pop the aluminum lose. Steel weld won't stick to aluminum. Just a thought it's worked for me many of times
1970 swb
2004 Dodge 4x4
Old 05-11-2011, 10:51 PM   #8
lakeroadster
Originally Posted by EZ4U2C View Post
Hey taank,
Good suggestion EZ4U2C. I have a piece of copper and a piece of brass that also works well as a removable backer bar.
Old 05-11-2011, 09:52 PM   #9
MotorSeven
Restoration Desperation
MotorSeven's Avatar
40 wire speed sounds high...have you tried it lower?
MotorSeven is offline   Reply With Quote
horse sheet, patch panels, wheelies!
