05-10-2011, 10:25 PM | #1 |
what to do?
okay, so i was in the process of taking off my wheel arch trim on my truck. this trim hasnt been off since 1979 so its on there good! and i got all screws but one stinking screw! and its really starting to pi** me off! any suggestions on what to do? thanks guys!
1979 GMC Sierra Classic Freshly lowered 5 inches |
05-10-2011, 10:37 PM | #2 |
Re: what to do?
PB Blaster or WD40 on the back (threaded) side of the screw and let it soak. Small vice grips on the back side to turn the threads. If too badly rusted in place you will have to snap the head of the screw off and drill out the rest of the screw with a smaller diameter drill bit, but I'll bet some lubrication will get it out. Good luck.
05-10-2011, 10:44 PM | #3 | |
78K & 79C Jimmys
Re: what to do?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
05-10-2011, 10:40 PM | #4 |
Re: what to do?
i tried WD 40 but i didnt try using vice grips. thanks man!
05-10-2011, 10:43 PM | #5 |
Robert Olson Transport
Re: what to do?
if worst comes to worst you can grind off the head of the screw with a dremel
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
05-10-2011, 10:43 PM | #6 |
Re: what to do?
Put the other screws back in.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-10-2011, 10:53 PM | #7 |
Re: what to do?
I'd try pb blaster.....I ended up using that when I had a really really tight sealt belt bolt...and it worked...and this bolt was so tight that when I tried to use a breaker bar I hurt my back bracing and the bar started to bent.....
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
05-12-2011, 07:56 AM | #8 |
Re: what to do?
i got it off, but thanks guys!
05-12-2011, 03:29 PM | #9 |
Re: what to do?
For all you guys that run into this again. I have a version of this tool
http://www.harborfreight.com/impact-...ase-37530.html And damn it works great when you need it. You just put it on the screw and crack it with a hammer and bam, it is loose. Just used it this weekend trying to get my mirror and vent window off. Just another good tool.
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
05-12-2011, 10:55 PM | #10 | |
78K & 79C Jimmys
Re: what to do?
