Old 05-15-2011, 03:41 PM   #1
roofingbloke
just finished my front crossmember section
here are some pics, 1.5"
roofingbloke is offline   Reply With Quote
Old 05-15-2011, 04:12 PM   #2
kyle87
Re: just finished my front crossmember section
wow! cleanest one i'v ever seen. awesome welds
kyle87 is offline   Reply With Quote
Old 05-15-2011, 05:39 PM   #3
68chevyLQ4
68chevyLQ4's Avatar
That looks really good. Nice work.
68 Chevy C-10. swb fleetside. 6.0 4L80E swap.
http://67-72chevytrucks.com/vboard/s...d.php?t=460877
68chevyLQ4 is offline   Reply With Quote
Old 05-15-2011, 07:20 PM   #4
broey
Square
broey's Avatar
pretty awesome man!
Squarebody Syndicate
broey is offline   Reply With Quote
Old 05-15-2011, 11:35 PM   #5
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Good looking welds!!! Let's see what kinda truck it's going on
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 05-15-2011, 11:43 PM   #6
ol_skool_chevy
ol_skool_chevy's Avatar
Wow........I agree Looks Great. I might be wrong, I dont know everything but that looks like alot of work for only 1 1/2 inch lower. whats the Gain? Im open to learning more..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 05-16-2011, 01:32 AM   #7
roofingbloke
In my opinion its either section the crossmember or do a Z in the chassis, i think this is an easier option to gain 1.5".
This was my last choice before spending lots of money on a aftermarket crossmember, i will allways choose self build over purchased items, thatway i gain more knoledge,
Old 05-16-2011, 08:26 AM   #8
csa daddy
csa daddy's Avatar
combined with a z of 3.5 this will net you 5 inches of drop. also depending on which body it is a z is required, i think in order to lay a square body on its frame in order to clear lower control arms. but to lay the pinch it will need a stock floor body drop or some kind of body drop to lay any kind of body
csa daddy is offline   Reply With Quote
Old 05-16-2011, 09:46 AM   #9
ol_skool_chevy
[B]I agree with your "[i will always choose self build over purchased items, that way i gain more knowledge," comment.
To me that might be one of the smarter comments I have seen here. Buying is not building. that's why the Ol' Skool Chevy Name..I build the way we did in the Old days Nothing new.
I guess my only thinking on your cross member was "what's the gain" but if your going seriously low I guess anyplace you gain ground clearance is a plus.
Again GREAT WORLK...............
/B]
Mark with Chalk
Cut with a torch
Old 05-16-2011, 12:00 PM   #10
Scot_Douglas
Scot_Douglas's Avatar
Great job!
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 05-16-2011, 12:14 PM   #11
charx2
charx2's Avatar
Wow, I wish I could weld like that!
My 67 c10 Thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=409192
charx2 is offline   Reply With Quote
Old 05-16-2011, 01:10 PM   #12
broey
Square
broey's Avatar
The 1.5 out of the cross member is still going to put the control arms and cross member on the ground. But it will help the truck sit a little more evenly when laid out. On my truck the crossmember needed a lot more work than a pancake to lay pinch.
Old 05-16-2011, 10:07 PM   #13
Scot_Douglas
This is with 2" out of mine with 2.5" drop spindles. (and temporary motorcycle springs that let is sit another 2" lower)
28.5" tall tires.
1966 C10
Build 'Fread
Old 05-16-2011, 10:55 PM   #14
ol_skool_chevy
[QUOTE=Scot_Douglas;4684271]This is with 2" out of mine with 2.5" drop spindles. (and temporary motorcycle springs that let is sit another 2" lower)
28.5" tall tires.
[/QUOTE
wheres your tie rod????????
Mark with Chalk
Cut with a torch
Old 05-17-2011, 07:23 AM   #15
Scot_Douglas
It's in there somewhere.
1966 C10
Build 'Fread
Old 05-17-2011, 09:05 AM   #16
csa daddy
csa daddy's Avatar
how about a little closer an more personal pic of your rack set up i like that. it looks awesome is that going to be ride height
Old 05-17-2011, 12:18 PM   #17
Scot_Douglas
There should be plenty in my build thread - and right now, I'm sitting about 2" lower than my targeted ride height.
Sorry for the thread hijack, Bloke!
1966 C10
Build 'Fread
Old 05-17-2011, 11:16 AM   #18
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I'm more interested in whats going on out back, I've seen a rack and pinion before.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-09-2011, 03:40 PM   #19
kieth
kieth's Avatar
I'm with you, that looks like a ?explorer independant rear suspension ???
i thought of that and wondered why no one would use it.
kieth is offline   Reply With Quote
Old 09-09-2011, 03:56 PM   #20
Scot_Douglas
Originally Posted by Rochlow View Post
For instance.. Let's say I "notch" the crossmember 2-3" under the frame rails. Then, use no-limits bolt in rack and pinion.
I know the frame will need to be notched for the rack, the spindles reemed out for the tie rods and the motor mount shorten or dropped..
That's the route I was looking at. Also I was think of moving the whole crossmember forward 1" to center the wheels in the wheel wells..
Not sure if this is an option..
That's dam-near what I did, but I used rod ends (without moving crossmember forward)
Originally Posted by SCOTI View Post
Hard to sat w/o trying. I will say to watch that oil pan. 2-3" is going to leave it hanging awful low (vs the x-member). If you raise the drivetrain, that will add the the amount of planning/work.
Porterbuilts Dropmember get's you there much easier....
While I agree Porterbuilt's dropmember would be easiest, Sectioning the crossmember DOESN'T change your crossmember-to-oilpan clearance. If you think about it, you leave the portion under the engine in the stock location and RAISE everything else around it. No change to motormounts or oilpan clearance:
Here's a good shot showing the stock motormounts in place:
Take a look-see in my build thread: It's a somewhat modified 1993 Ford T-bird SC IRS. They can be had for cheap and I wanted to shorten my wheelbase a bit (explained in my build thread) - was much cheaper than building a proper 4 link ( I didn't want to mess with moving the entire stock suspension forward)
1966 C10
Build 'Fread
Old 05-17-2011, 11:34 AM   #21
ol_skool_chevy
I see now at that angle. No tie rod, you used rack...nice
Mark with Chalk
Cut with a torch
Old 05-19-2011, 05:34 PM   #22
smashingchuck
Nope, nothing is wrong , that's what happens when you go 1.5".
78 Build Thread
4Runner Build
Old 05-19-2011, 07:23 PM   #23
SCOTI
SCOTI's Avatar
Yep. The possible steering related issues are mentioned in most (if not all) of the notched/pancaked/sectioned x-member threads. Hard to miss....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-20-2011, 01:54 AM   #24
roofingbloke
From the many people who had done this, most had done a 2" section experienced steering issues, thats why i went with 1.5",
Oh well, tape measure out again, my options are, move my steering up the same 1.5" or go rack and pinion,
Thanks for the replys.
Old 05-19-2011, 05:41 PM   #25
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Mine required some grinding at 1.25" so I can imagine you'll need some at 1.5".
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
