![]() Join Date: Mar 2001
np205 Rebuild Question....Idle Shaft
I just installed the idle shaft and gear in the np205 I am rebuilding. I know you are supposed to install the shims and spacer between the bearings and check the end play. I thought I was good with zero end play, but then I installed the idle gear/shaft into the case and torqued the shaft nut to 135 lb.ft (also read it is supposed to be 200) I installed the same 3 shims that came out of the assembly. I had new races put into the idler gear. When I tried to torque down the nut it just froze the gear assembly. I backed off the nut and reset to about 75lb.ft. It spun freely without any binding and there was zero end play in the gearset. Do I need to pull it out and add a shim so I can torque to 135 (or 200) lb.ft? Advice from anyone with some experience here would be much appreciated. Thanks
John
63 Buick Wildcat 425 72 Chevy Blazer CST 72 Chevy C10 Cheyenne 00 Ford F-350 Super Duty 7.3L 09 Dodge Challenger SRT-8 10 Ford Expedition Limited |
Junk Yartist
Re: np205 Rebuild Question....Idle Shaft
.001-.002 end play. 135lbft.
There is a spacer sleeve that goes between the shims and one of the bearings. Do you have that installed?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
Yes I put the shims in, I ordered some more shims last night from some website....quad 4x4 I think.....$35!!!...I need to add some to get the space between the bearings set right. I'm not sure why I need so much more shim after putting new races/bearings in.
Thanks John Posted via Mobile Device
Junk Yartist
I was referring to the sleeve that is pictured between the shims and the bearing. without it the bearings will just LOCK when the nut is torqued. Hope that helps.
Yes I put the sleeve in too....the bearing races must be a little different somehow. thanks
Junk Yartist
You may laugh at this picture, but this is how I pre-loaded my bearings to set my shim pack before installing it. I am almost done rebuilding my 205. I photo documented the whole thing. I will post them up once it is all back together.
