Old 05-16-2011, 01:26 PM   #1
Ackattack
Ackattack's Avatar
5 speed manual question
I'm looking to buy a early 90s TBI truck to install the TBI onto No Buck. If I could find a truck with a 5 speed that would be a bonus. What 5 speeds were available back then? Is the V-6 5 speed the same one that was behind a V-8?
I don't know if I'd actually swap the 5 speed into no buck since it already has a 4 speed and 3.08 gears (OD may be too much for it). But I figure it would be nice to have the option.
Ackattack is offline   Reply With Quote
Old 05-16-2011, 02:16 PM   #2
Clyde65
Clyde65's Avatar
Re: 5 speed manual question
NV3500/NV4500,
The S10's had a 5speed also.
Those were very light duty. the NV3500 was behind some of the truck v8's
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-16-2011, 02:55 PM   #3
Ackattack
Ackattack's Avatar
was the nv3500 behind the v6 in the full size trucks?
Old 05-16-2011, 05:08 PM   #4
67k5
I have a 4.3 ,5 speed,(nv3500) in my 67 shorty,and love it.3.08 dif.Great on fuel,can't spin the wheels much,but cruzes great.
67k5 is offline   Reply With Quote
Old 05-16-2011, 09:26 PM   #5
LEEVON
Moderator
LEEVON's Avatar
NV3500, granny low and o/d. I had one behind the 4.3L TBI and it went 200K without any issues, except a clutch because my sister learned to drive stick on it.
They did also come behind V8's like clyde said.
I believe the clutch is hydraulic and on the passenger side?
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 05-16-2011, 10:24 PM   #6
coops714x4
coops714x4's Avatar
excuse me Ackattack I am NOT trying to hijack your thread but I have a question I am going to run a 454 and I want to put the nv4500 behind it. I know the 4500 is a hyd clutch set up BUT can it be mated to a older bellhousing and run a conventional clutch with a throwout bearing ???? COOP
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 05-17-2011, 12:35 AM   #7
Captainfab
60-66 Nut
The NV3500's were behind some of the 305's and 350's. They will hold up fine as long as you don't beat on them too much. IIRC they are rated at 300 ftlbs.. My son inlaw has a '96 K1500 with the L31 Vortec and a NV3500 behind it. The L31 Vortec is supposed to put out 330 ftlbs.
Old 05-22-2011, 09:43 AM   #8
COOTERUSN
Read notes above.
Is there a 5 speed that will bolt directly into a '68 C10 with no modifications.
Truck began life as a 6 cylinder. Already has a stock 3 speed, drive shaft, and 12 bolt I changed to 3:08 posi Has a 350 in it now.
COOTERUSN
Last edited by COOTERUSN; 05-22-2011 at 09:45 AM. Reason: clarify "with no modifications"
COOTERUSN is offline   Reply With Quote
Old 05-23-2011, 01:26 AM   #9
Captainfab
60-66 Nut
I am not aware of any 5 speed trans that will be a direct bolt in with no modifications. .
Originally Posted by COOTERUSN View Post
Read notes above.
COOTERUSN
Old 05-23-2011, 11:39 AM   #10
Clyde65
Clyde65's Avatar
Well, if the NV3500 was behind some V8's and V6's, why wouldnt they just bolt up? the v8's we are talking about are 350TBI's right? The v6's are just 350's with 2 cylinders chopped off.
I think they would bolt up no problem, however I bet there is a difference in bell housings, I would go to a boneyard and pick up a 5speed with all the hyd stuff
Clyde65
Rebuild of Clyde
support our troops!
Old 05-23-2011, 11:45 PM   #11
Captainfab
60-66 Nut
Yes that is true, the NV3500 will bolt up to a 350. But the driveshaft will need to be shortened. Since the NV3500 is a hydraulically operated clutch, the truck will need to be converted over to a hydro clutch. Then depending on what trans hump he has, that may need to be changed.
COOTERUSN asked about a 5 speed conversion with nomodifications.....I don't think this qualifies as no modifications.
