Old 05-18-2011, 10:19 AM   #1
sscooter
3800 Supercharged V6 in C10?
My parents have a '98 Park Ave Ultra with the supercharged 3.8. The car only has 100,000 miles on it and runs superb. The body however, is starting to fall apart. They've owned it since '99 so its time for a new car... I may be able to get it for little/nothing.
I have read that it is possible to use the tranny from a late '90's Camaro as it will bolt right up.
the 350 in my truck is very tired, and it would be a fun project for the winter.
Ive seen 30 MPG in that Buick on the highway, and it goes pretty good with the 240 HP V6...
Anybody here done this swap or know of anybody that has?
sscooter is offline   Reply With Quote
Old 05-18-2011, 11:38 AM   #2
pmkrew
Re: 3800 Supercharged V6 in C10?
Sounds like a cool swap though! That may just be because I know where there is one of those engines also... ;-)
pmkrew is offline   Reply With Quote
Old 05-18-2011, 12:17 PM   #3
chevyrestoguy
chevyrestoguy's Avatar
Are those cars front wheel drive?
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-18-2011, 01:59 PM   #4
62 Longbed
62 Longbed's Avatar
Yes that should be a FWD car ... I had a 97 Pontiac GTP , car scooted very nicely with the Supercharged V/6 .... It would probably be more fun in a S-10 , alot lighter . Just my 2 cents
62 Longbed is offline   Reply With Quote
Old 05-18-2011, 12:13 PM   #5
Clyde65
Clyde65's Avatar
Are the Buicks FWD or RWD?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-18-2011, 03:01 PM   #6
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
They are a front drive car. But the original post states that he may be able to bolt the motor to a Camaro transmission. Which would then make a drivetrain that is rear drive. It would be different for sure. If you do it, do the intake gaskets while it is out. You dont want to do them in the truck. A lot more work.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 05-18-2011, 03:45 PM   #7
shortbed70
shortbed70's Avatar
Intake gaskets are a must if you do the swap and you should be able to find a tranny out of a camaro that will bolt too it. Be ready to do some fab on motor/tranny mounts, exhaust. Keep us posted if you do it.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-18-2011, 03:54 PM   #8
Pop's C-10
Pop's C-10's Avatar
It will work with a f-body trans...jus do think get 30 mpg when it in tha truck..And they make a boat load of hop up parts..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-18-2011, 05:15 PM   #9
kieth
kieth's Avatar
I am looking for one of the new camaro v6's with a 6 spd auto 300hp 29mpg now that is cool..
kieth is offline   Reply With Quote
Old 05-20-2011, 01:53 AM   #10
bluex
bluex's Avatar
Yes, it will bolt up to a camaro trans. I have an engine out of a 06 grand prix in my '97 firebird. The 3800 in the camaro/firebird is the same in long block form as the FWD ones. The only differences are the intake/exhaust mainfolds and sheetmetal. They even use most of the same sensors. Try to find a set of the engine side motor mounts from a camaro/bird, they will be easier to work with in RWD mounting than the FWD mounts.
These are good engines and it should last you another 100k if its been maintained correctly....
edit:
I forgot the heads on the SC versions are different. They have the mounting bosses for the fuel injectors in the head instead of the intake because of the supercharger. They also have a sligthly lower compression ratio (I think)
bluex is offline   Reply With Quote
Old 05-20-2011, 09:33 AM   #11
joedoh
joedoh's Avatar
this is a great idea, if you need any help with wiring I would be glad to support this swap.
Old 05-20-2011, 11:34 AM   #12
NCD1966
NCD1966's Avatar
Not to burst anyones bubble, but I think you may have trouble with the motor mounts, being they were for a fwd car.
If you want to go with a modern motor, I would go with a 5.3 LS truck motor. They make good hp and torque, and get good fuel mileage. Also its made for a truck. Just my opinion.
And for side note; Im know you can use a old th350/400 or old school manual for the LS motors.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 05-20-2011, 11:44 AM   #13
Scot_Douglas
Scot_Douglas's Avatar
The 3800 was put in the Camaro for production, so I don't think motormounts will be much of a concern.
:bubblesnotburst:
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 05-20-2011, 09:56 PM   #14
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
I kind of like the idea. It would be worth a shot if you want to be different, especially with everyone (including myself) doing a LS swap.
I'd try to find everything out of a V6 camaro; manifolds, tranny, flexplate, starter, ect.
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 05-21-2011, 01:41 AM   #15
bluex
bluex's Avatar
The camaro V6 stuff is stupid expensive. At most I would use from one for a truck application is the engine side motor mounts and a set of 00+ exhaust manifolds. The rest you can use from the FWD car. Maybe use the F-body oil pan if needed since the FWD one is basically flat. The intake can be flipped around so it faces the accessory drive instead of the trans and the FWD one is actually a better design than the F-body. There is plenty of room in one of these trucks so really no need to spend the extra $ on F-body specific stuff.
Also all the series 2 and series 3 engines are the same. The difference is a series 3 has a little bit better/stronger connecting rod and a slightly larger exhaust valve. I've done all the reasearch on this since I put a 06 series 3 in my firebird that had a 97 series 2.....
Old 05-21-2011, 09:03 AM   #16
tapeworm
tapeworm's Avatar
I was wondering about the accessories on the front of these; its nice to know the FWD stuff works.
Are pulley swaps & blower porting commonly done on these?
Old 05-23-2011, 07:36 PM   #17
Pop's C-10
Pop's C-10's Avatar
yes...but there are other mods that need to be done before you start droping pully sizes...google tha term top swap
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 05-23-2011, 09:03 PM   #18
mcmullinauctions
McMullin
mcmullinauctions's Avatar
What sort of fuel mileage numbers do you think a v6, 5 speed manual, and high ratio rear would achieve?
mcmullinauctions is offline   Reply With Quote
Old 05-22-2011, 10:59 PM   #19
bluex
bluex's Avatar
The fwd accessories won't work in an f-body, but they should not cause a problem in this style truck. They won't work in the f cars cause the layout is all wrong.
The V6 f cars are 10 lbs of stuff in a 5 lbs bag. The V8 is 15 lbs, lol.
Intake gaskets are a common problem. I don't think they would be too hard to do in the truck engine bay.
I'm not as familiar with the s/c specific questions. A good place for that info would be club gp. Don't expect to get another 100 HP with a pulley swap. These engines are not intercooled....
Old 05-22-2011, 11:58 PM   #20
yunkyarddog
yunkyarddog's Avatar
takin notes if it works my next project is my 52/s10/park ave. motor
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time
94 s10 4x4 4.3/5speed (dd)
68 lwb GMC 350/4speed
52 5 window GMC I6/4speed 12v (8lugs and long bed)
53 bel air 235 I6/powerglide
yunkyarddog is offline   Reply With Quote
Old 05-23-2011, 11:41 PM   #21
Blue666
The Buick 3800 was always one of GM's best engines I could never figure out why GM did not use it more often. It would have made the S-10, Fiero and lots of other cars more fun. The 2.8 & 3.1 engines were just terrible.
The 3800 was also used in the Buick GNX, I had the the early version (231 cu in) as the stock factory engine in my 71 CJ-5.
IIRC the GNX was available as normal aspiration, turbo & supercharged with standard rear drive configuration. Those parts may be rare but they are out there. Not sure if any aftermarket manifolds or other parts are available.
Good Luck with the build!!
Blue666 is offline   Reply With Quote
Old 05-23-2011, 11:44 PM   #22
Blue666
Sorry, I meant to say I had the stock, normal aspiration version in my 71 CJ-5. I did not have a supercharged Jeep, but that could be a really fun ride.
Old 05-24-2011, 05:14 AM   #23
bluex
bluex's Avatar
The earlier series 1 3800 like your talking is a very different animal. It won't interchange with a series 2 or 3. Lots of internal and external differences.
It is still possible to swap it in a truck though as it was also in other rwd applications. Your going to pay a lot more for a GN engine to I bet.
