![]() Join Date: Oct 2007
What would you do?
About 4-5 years ago I bought 2 sets of the heavy duty headlight kits from LMC. I ordered the wrong sets and got the ones for GMC's with the 4 head light hook ups..
First ,I will ask if anyone has modified a 4 headlight set up to a 2 headlight set for use in the Chevy Trucks? If so,would you let me know what you did to make it work . What would you do? Modify them ,,,sell them,,,or see if I can return them?
When you learn a thing a day you store up smart. |
Active Member
![]() Join Date: Jul 2007
Re: What would you do?
Just curious...
Whats a heavy duty head light kit? Whats the difference between heavy duty and non heavy duty? |
Active Member
Did a search...
Disregard if you meant the heavy duty headlight wiring harness kit. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
What all does the kit entail? I know that if the high beam lights are wired into the kit the same way GM wired the GMC high beams, then you should be able to just cut off the high beam plug. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Here is a picture of the wiring harness I have ..It is a 100/90w high grade head lamp tune up kit .
![]() it comes with relays and instructuons for a 4 head light wire up this is the pkg ![]()
When you learn a thing a day you store up smart. Last edited by GOPAPA; 05-18-2011 at 11:35 AM. |
Active Member
fyi: not sure if part number has changed but LMC shows this item as being for 60-66 GMC and 60-61 Chevy.
http://www.lmctruck.com/features/cbe/CBEEL2.htm |
#7 | |
If you want to sell them I am definately interested!
-Scott- |
20' Daredevil (Ret)
![]() Join Date: May 2003
Larry... like Wes said above, you can just cut off the high beam (2-prong) connectors or trim them out. That's what I would do, if you need a harness for a Chevy. The remaining 3-prong plugs have high, low, and ground for 7" single headlamps.
Or just sell the harness. I doubt it could be returned after that much time.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#10 | |
thx for the offer to buy them ,,but as you have read from a couple on here that I can still use them .. [QUOTE=Stocker;4688026]Larry... like Wes said above, you can just cut off the high beam (2-prong) connectors or trim them out. That's what I would do, if you need a harness for a Chevy. The remaining 3-prong plugs have high, low, and ground for 7" single headlamps. thx for the second opinion agreeing with Wes ,, I will put them away until I get to it.. and install them ..
Or just tape the extra high beam wire back. No biggie, unless you are building a show truck. The lights will not know the difference.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
You got it ,,as I dont have show trucks .. bob it off ,,wipe some of the grease off an ol wire nut ,,screw it on the dead end and hook er up.
