Old 05-18-2011, 07:13 PM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
How to patina aluminum/pot metal in one day???
Okay.....let me explain. I recently got in one of the more rare Holley GM muscle car carburetors (If you must know, it's a list 3247 '66 CORVETTE 425hp 427 carb). The fact that the guy that listed it on ebay and had know idea what it was is irrelevant. The fact that I paid $45 SHIPPED is also irrelevant. The fact that it is worth hundreds of dollars in unrestored condition is further irrelevance!
Now that I am done boasting, here is the issue. The carb is 100% correct except it doesn't have the vented front bowl. It's only 2 more machining steps that Holley did to their stock center hung 4160/4160 bowls. I can buy them pretty cheap new but it will look very odd on a 45 year old carb. I drilled the 2 necessary holes and tapped the one, so that part is done. Now I have two super bright and shiny holes in a very old bowl and I need to figure out how to dull up the 2 holes so they look like old metal. What can I use to really dull up the shiny part the new holes made? Thanks!
prostreetC-10 is offline   Reply With Quote
Old 05-18-2011, 07:21 PM   #2
Toms1968
Toms1968's Avatar
Re: How to patina aluminum/pot metal in one day???
If they are brass try using white vinigar or muratic acid. I know it works on copper flashing and some raw sculpted brass. Good luck.
Toms1968 is offline   Reply With Quote
Old 05-18-2011, 07:46 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Here you go....
Member Nr. 2770
Old 05-18-2011, 11:27 PM   #4
ERASER5
ERASER5's Avatar
Sodium Carbonate + water should blacken aluminum real quick. Steel wool would shine it back up to what ever degree you want. You can find sodium carbonate at any pool supply store. It will be call PH UP or something like that.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-18-2011, 11:51 PM   #5
cheyenne shortstep
cheyenne shortstep's Avatar
Muratic Acid will blacken aluminum instantly, giving an aged look. Just did this to a set of Z/28 valve covers.
cheyenne shortstep is offline   Reply With Quote
Old 05-19-2011, 01:28 AM   #6
scrapmetalart
Junior Member
yep. kinda gives an old magnesium look just not as black
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 05-19-2011, 11:17 AM   #7
POPO1984
POPO1984's Avatar
use hair and grease remover it will dull the **** out of aluminum
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 05-19-2011, 12:52 PM   #8
prostreetC-10
My Carbon Footprint
I am about to pull the bowls out of some nasty carb cleaner I had. I remembered that it did a good job of discoloring carb parts when I didn't want it too! lol
I didn't post any "pichers" because the parts have been in the cleaner. I don't have a solvent resistant underwater camera!
