05-19-2011, 03:33 PM | #1 |
Rear shock mount picture
Can someone post a picture, or link to a picture showing a shock mount on the driver side rear axle.
Having an issue with the shock on that side and with a shock extender. Or can you tell me if this one is abnormal?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
05-19-2011, 07:23 PM | #2 |
Re: Rear shock mount picture
I know that if you add a lift kit the passenger side wont fit without some work, but, I've never seen that problem on the driver side
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
05-19-2011, 08:21 PM | #3 |
I just added extenders to my 73 2wd blazer. Both of the shock mounts were identical on either side (other than facing in different directions.) There have been others on this forum that had similar issues as you though. See post #69.
http://67-72chevytrucks.com/vboard/s...=281883&page=2 |
05-20-2011, 12:43 AM | #4 | |
The rear-end I am using came out of my 4x4 but I swapped in 5-lug axles. I guess there is one small difference between the 4x4 and 2wd axle housings... This picture is from my '82 2wd K5.
05-19-2011, 08:37 PM | #5 |
I had the same problem...I could only use 2 of the 3 bolts on each shock extender.
