05-23-2011, 08:48 PM | #1 |
header help!!!!!!!!!!!
Hey guys i really need advice choosing what headers to buy. 67 c10 1/2 ton 327 with th350 mild build with 327. do i want 1 1/2, 1 5/8, 1 3/4? long tube, shortys? helpppppp lol
327 fresh rebuild 1000 miles ago bored 020 std crank (forged) heads 65cc 1.9" I 1.5" E cam clevite #229-199 duration @ .050 cam lift int. 224 exh. 224 sae duration 298 298 lobe centers 107 117 lash hyd. gross valve lift 465 465 cam lift .310 .310 Last edited by snaus32; 05-23-2011 at 09:06 PM. Reason: specs |
05-23-2011, 09:10 PM | #2 |
header help!
Hi guys ive posted in engine section as well hate to do both but im in a pickle and need to order my headers asap! Any help would be great i'm a novice at this stuff.
Hey guys i really need advice choosing what headers to buy. 67 c10 1/2 ton 327 with th350 mild build with 327. do i want 1 1/2, 1 5/8, 1 3/4? long tube, shortys? helpppppp lol 327 fresh rebuild 1000 miles ago bored 020 std crank (forged) heads 65cc 1.9" I 1.5" E cam clevite #229-199 duration @ .050 cam lift int. 224 exh. 224 sae duration 298 298 lobe centers 107 117 lash hyd. gross valve lift 465 465 cam lift .310 .310 |
05-24-2011, 06:46 AM | #3 |
Re: header help!
no sugestions?
05-23-2011, 10:39 PM | #4 |
Gentleman Jim owner x2
Re: header help!!!!!!!!!!!
I'd go with 1 1/2" shorty's with a 3" collector. You won't need block huggers, and long tubes vs shorty's are a question of clearance with your frame. The bigger primary tubes will touch your spark plug wires and burn them off, and your engine will run like sh*t until you figure it out. Don't ask me how I know this. I have a 350 with block huggers, and they're OK for what I want. I had some long tubes with bigger primary tubes and HATED them because I went through new spark plug wires about once a month, even with the short "header spark plugs".
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
05-23-2011, 10:52 PM | #5 |
I used Sanderson mid length, no clearance issues.http://67-72chevytrucks.com/vboard/a...1&d=1306205499
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 |
05-23-2011, 11:24 PM | #6 | |
Do you happen to have a part number for those?
Thanks Quote:
Jay 1956 Chevy 210 Sedan 1970 Camaro Z-28/RS 1970 Chevelle SS 396 (numbers matching L34 car) 1971 Chevy SWB Fleetside with 1967 front clip - in progress My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438156 |
05-24-2011, 12:59 AM | #7 |
those r nice
05-24-2011, 06:54 AM | #8 |
I am running hooker headers on mine. They are full length 1 and 5/8ths with 2 and 1/2 inch collectors. I have run these headers in the truck with three different engine (305, 307, and 350) and they all ran great. I han no plug boot issues with stock heads or aftermarket. I run 8.5mm MSD super conductor wires with the "flex" boots. I will try to get a picture today with my current set up.
1990 S10 Reg. cab 2wd 2.5/ 700r4, lowered, soon to be a TBI 350/ 700r4 1993 2500 Reg. cab 4wd 6.5 turbo diesel/ 5spd, bigger turbo, Bull Moose pump, cold air intake, and a few other mods 1969 C10 Reg. cab 2wd 305/350, RHS heads, Voodoo Cam, Gilmer drive, 2400 stall, and lots of other goodies! |
05-24-2011, 09:03 PM | #9 |
Her's a link. I looked on my bill & it has a different prod.#, but that's them. Code on my bill is 11-67772HDRS.
http://www.earlyclassic.com/catalog....gory=New+Items that link didn't work very well, just look under headers, the code on their site is 11-6572HDRS.
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 Last edited by gonnuts; 05-24-2011 at 09:11 PM. |
