Old 05-24-2011, 09:55 AM   #1
smorg007
smorg007's Avatar
What is the easiest way to remove woodgrain tailband tape.
I've made the decision to re-do my own woodgrain tailgate band. I've ordered the woodgrain tape from Cheyenne Super-Man. I will hopefully re-use my own metal letters. My question is what would be the best way to remove the old woodgrain tape. Is their a chemical that penetrates the 38 yr old tape and dissolves it enough to be removed with scrapping and scratching the original surface. I have a another band that's in bad shape that I can practice on. Any help or suggestions from those who have done this is appreciated. Thanks
smorg007 is offline   Reply With Quote
Old 05-24-2011, 10:11 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: What is the easiest way to remove woodgrain tailband tape.
try spraying some penetrating oil and a razor blade, or 3m makes a woodgrain removal spray. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 05-24-2011, 10:44 AM   #3
smorg007
smorg007's Avatar
I wonder if regular gel type paint remover would work. Out to the garage I go.
Old 05-24-2011, 11:13 AM   #4
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Give Goof-off a try. Available nearly everywhere.
Zoomin is offline   Reply With Quote
Old 05-24-2011, 11:35 AM   #5
DesertCat
DesertCat's Avatar
I dealt with tons of woodgrain in the 70's-80's... start with a heat gun. Don't get it too hot, work a little at a time and pull it off. It works.
Then use tar and bug remover for the adhesive. Not fun but really it's the fastest and easiest way.
Good luck!
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 05-24-2011, 12:40 PM   #6
70shortfleet
70shortfleet's Avatar
Good luck!
70shortfleet is offline   Reply With Quote
Old 05-24-2011, 01:48 PM   #7
sameyrasmea72
sameyrasmea72's Avatar
I would stay away from real harsh chemicals. I am not positive but I think the aluminum is coated or anodized like the grill.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 05-24-2011, 02:06 PM   #8
bikerbuck
Ive been removing 20 year old decals and you name it for years. The only and best way to remove without damaging under surface with not that much effort is to use a eraser wheel. Put it on a drill and go to town. It takes a little time depending on how big of area your doing but very good results.I get mine at Napa auto parts.Ill try and find a part #.
bikerbuck is offline   Reply With Quote
Old 05-24-2011, 06:23 PM   #9
jaros44sr
jaros44sr's Avatar
that's what I was thinkin', I think Eastwood sells one
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-24-2011, 11:51 AM   #10
7T2
Active Member
7T2's Avatar
For removing the adhesive residue, I've found that most products like "goof-off" work well, but only work for a short period of time. You spray it on, then wipe off the adhesive before it gets sticky again. If you let it sit the remover seems to evaporate and the adhesive gets sticky again. I've found it best to spray a little area, get it all clean, then move to then next spot. Sparying it all at once thinking it will saturate the adhesive turns out to be a waste of money. It's not something to let set overnight, or even a couple of minutes. Something like WD-40 might work that way though.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 05-24-2011, 03:30 PM   #11
brad_man_72
the boat guy
brad_man_72's Avatar
termites!
brad_man_72 is offline   Reply With Quote
Old 05-25-2011, 12:29 AM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
Just did this today on a couple of pieces of trim. Leave 'em out in the sun for a while, and the woodgrain will peel off in one piece, leaving very little residue. What is left is eaten away easily by acetone. I found this out after scraping and goof-offing another piece. Waaaay easier to let it get hot first...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-02-2011, 11:30 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
Anyone have a secret to putting the woodgrain back on with the letters on
I really don't want to take them off
Old 06-03-2011, 11:28 AM   #14
smorg007
smorg007's Avatar
Hi Jonathan,
That would be a quite the feat and I would like to see a step by step photo of that process. I'm glad I kept my original band and replaced the woodgrain tape, because it came out better than I expected. I now have a whole set of new unused letters and clips to sell since I re-used my own metal letters The old tape came off in one easy piece using a blow dryer and patience.
Old 06-03-2011, 02:54 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by smorg007 View Post
Hi Jonathan,
Nice job. I just scored a super nice band off ebay for $30 shipped to me It was black painted but it's faded. The letters are chromed metal and in good shape and the overall band is still shiny and the outer black is perfect.
So did you drill out the backs and then epoxy to re-attach the letters? Any advice is appreciated. I already have the new tape to use and a matching set for lower moldings so I can put together a super nice set.
Old 06-03-2011, 06:11 PM   #16
smorg007
smorg007's Avatar
My band must have been a reproduction or at least my letters were at one time or another because they were attached with the same push on type clips that was in the package with the replacement metal letters that I bought from GMC Pauls. These clips were available at my local Ace Hardware Store.
The difference for me was my letters has the GM part numbers cast in them and I had no reason not to re-use them. I was anticipating having to drill out the posts on my band so that's why I bought the replacement letters before removing my band, otherwise I would have noticed how they were attached and would not have bought the ones I did.
Sorry my story can't help you.
Old 06-03-2011, 04:19 PM   #17
mcbassin
Still Learning
mcbassin's Avatar
Hey your gate turned out super! You want to sell those extra letters? are they metal or plastic? thanks
Old 06-03-2011, 06:41 PM   #18
smorg007
smorg007's Avatar
mcbassin,
Letters are metal with round circular push on clips for attachment to the band. GMCPauls part number is 381656, I paid $59.95 plus tax and shipping = $82.25. I'm gonna call and see if I can return them, don't know if there is a restocking fee or not either. The letters are individually in their own plastic sealed bags and the clips in another then everything in another plastic sealed bag. I opened the outer bag to compare the letters to mine. Depending on what I learn will determine which way I go. Have a great day.
Old 06-03-2011, 02:55 PM   #19
tim21391
tim21391's Avatar
i just used a razor blade and laquer thinner on mine
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
