Old 05-25-2011, 03:24 PM   #1
Phil750
Question Fuel needle jumps
On my 86 C-20 the Fuel Needle is never steady. Is there any easy fix to this problem.
Thanks for any ideas.
Phil750 is offline   Reply With Quote
Old 05-25-2011, 03:36 PM   #2
tucsonjwt
Re: Fuel needle jumps
In my experience, aftermarket fuel sending unit will cause the fuel gauge to move on acceleration, stops, and turns because of the design/low quality of the sender and resistor. If your gas gauge stops moving and shows the correct fuel level at some point, then I would suspect the sending unit.
tucsonjwt is offline   Reply With Quote
Old 05-25-2011, 04:38 PM   #3
craig@ridetech.com
Formerly LSC71
I ran into an issue on my 76 where the needle was randomly jumping. Turned out the wire from the sending unit to the gauge was pinched and my guess is that is was getting signal intermittently causing the needle to jump. After I found that I cut and respliced the wire and it's been great ever since.
craig@ridetech.com is offline   Reply With Quote
Old 05-26-2011, 11:24 AM   #4
Phil750
Thanks for your help. I will check both.
Old 05-26-2011, 06:14 PM   #5
78 Chevyrado
Is it constantly the same amount unsteady no matter the level in the tank? If so it's probably a wiring problem of some sort.
Otherwise it should be rock steady at full, get worse towards the middle and fluctuate quite a bit on the last 1/4 of the tank. If it does this, it's the fuel sloshing, IIRC they didnt put baffles in the tanks until EFI.
It could also be a combination of both.
78 Chevyrado is offline   Reply With Quote
Old 05-27-2011, 08:26 AM   #6
Chris' 86
Chris' 86's Avatar
The first time that my tank got below half, this scared the hell out of me. I just bought the truck and I thought it was dumping fuel. Thought I was gonna be stranded a few miles from the house.
Chris' 86 is offline   Reply With Quote
Old 05-27-2011, 01:36 AM   #7
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Had that problem and traced it to the wire from the sending unit as it ran along the frame on the passenger side, right below the door. It was a frayed wire that was grounding to the frame. A little electrical tape and problem solved!
78 Big10 454 is offline   Reply With Quote
