05-29-2011, 04:25 AM | #1 |
what carb are all you bbc folks running ?
so im just wondering what you all with 396-402 big blocks are running for a carb, and if you have gone smaller for mpg? any input is great, oh along with carb what other mods (engine wise ) are you running ? thanks all.
05-29-2011, 05:27 AM | #2 |
Re: what carb are all you bbc folks running ?
I am running the stock Q-jet. With the smaller primaries and large secondaries it works very well on the big blocks.
JIm
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
05-29-2011, 06:38 AM | #3 |
05-29-2011, 07:04 AM | #4 |
Stock Q-jet on my 396
"You gonna pull them pistols or whistle dixie ?" |
05-29-2011, 10:14 AM | #5 |
Edelbrock 750, 465 BB, 400HP and 450 lb/ft Torque.
05-29-2011, 10:17 AM | #6 |
its all about the +6 inches
I had a quadra jet rebuilt for my 402, I had thought it was a big block carb when I had it done, ran like crap. Bought an Edelbrock 750 (same as on the cad 425) and love it.
I guess once I get the small motor ready for the longhorn I have a fresh quadra jet for it. |
05-29-2011, 10:34 AM | #7 |
750 Edelbrock here
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
05-29-2011, 12:00 PM | #8 |
Junior Member
I am running the stock Q-jet off of my 350 on a stock 454 and it is working out ok.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
05-29-2011, 03:22 PM | #9 |
Thanks all I'm just weighing options . Iv got a holley 570 was going to use on a small block I don't have any more . Way too small I'll probably sell and get a 700 + cfm for the truck thx again
Posted via Mobile Device |
05-29-2011, 06:39 PM | #10 |
As an old Mr. Goodwrench graduate........(1978 thru 1983).........
Wentworth Chevrolet Truck Shop......... Portland, Oregon I learned all the tricks from the best of the best on how to repair....modify.... or maximize the Rochester Q-jet. There is no doubt, if done properly, that the R-Chester 4-Jet is the best carb available for BBC heavy duty applications. A good Q-jet tech can give you the best performance and economy from the same carb if ya' give him time to Dyno or road test the jet & needle sets... Most anyone who has ever jumped into a rig with a big-block and stepped on it got quite a thrill either from "off the line" or from the mid rpm torque curve, but if you invest some time & patience into it......you can get the full yield of torque possible...bottom to top....from your BBC with that carb. You can get pretty close by the #'s on the bench. But by actually putting the engine to work, you can find that magic combination that makes that big-block just sing.... Just sayin'........(not sellin')
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
05-29-2011, 06:47 PM | #11 |
For the record....
We recorded well over 1000 CFM on the stock Q-Jet off of a '76 454 truck on the bench. That's a ton of air. Needless to say..... you sure do need to get it right on the fuel/metering end. There should be a Q-Jet wizard somewhere near you. He's probably really old....or busy fishin'.
05-29-2011, 10:18 PM | #12 | |
05-29-2011, 10:33 PM | #13 |
Stock Q-jet on my 402 Just got it refurbished and its on its way to Ohio from Ca.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 05-29-2011 at 10:34 PM. |
05-30-2011, 01:32 AM | #14 |
My Carbon Footprint
Hmmm.....having a really hard time buying it. What flow bench did you use? You're telling me you got a stock 750 to well over 1,000? Please provide details.
05-29-2011, 10:58 PM | #15 |
awsome 70cst thank you much for the info.
05-30-2011, 10:05 AM | #16 |
2WD Jimmy
The Quadrajet is an awesome carb if rebuilt correctly.. I would suggest the Carb Shop in Ontario Ca. Just cleaning it and putting in a carb kit is Not a rebuild. just sayin.
05-30-2011, 10:07 AM | #17 |
Holley 600 CFM on 454!
Trevor "You already said spite" |
05-30-2011, 12:06 PM | #18 |
Not Mine But A beauty
750 Mighty Demon on a 454
68 Chevy Shortbed 454/400 2000 Chevrolet Camaro SS 6spd 2011 Silverado 5.3 6spd auto |
