67 with 73-87 calipers?
Here's the deal, I broke a brake hose to the caliper and I had the parts store bring out a 71-72, 73-87, and nothing matched mine. So, because I need calipers anyways I can pull mine and have them run the part number and get whatever these are or can I use the 73-87 calipers and brake hoses? I have the 73-87 spindles with the 6lug conversion rotors. Thought I'd ask first since something could vary for all I know. I think the rotor thickness may vary?
Posted via Mobile Device |
Re: 67 with 73-87 calipers?
Bump! Really need to know so I can buy calipers this week.
Active Member
![]() Join Date: Jul 2007
ttt
Try to find out what you have first. If there's a shop that specializes in brakes near you take them the part/parts. Most of these guys have seen a lot of different ones and may be able to identify it for you. Also, I found out that the local autozones and oreilly's don't take the time or have the knowhow to look in catalogs. Take it to CarQuest if you have one, and see if they can match numbers for you. |
I think a Oreillys was the one I went to. Came out with everything but the one I had.
