synthetic oil vs. regular oil
I have a 76 k10. I've heard from many different people that I should use either full synthetic or half n half. I just wandering what the thoughts are on here, being that the people on here know more than the people I work with.
Marshall 1976 Chevrolet K10 4wd 2006 Chevrolet Impala (wife) IF IT JAMS FORCE IT!! IF IT BREAKS, IT NEEDED TO BE REPLACED ANYWAY!! ![]() |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: synthetic oil vs. regular oil
You don't hear much about engine failure from lack of lubrication with dino, which is why I still use it. That and it is less expensive.....
I would use full synthetic if I had an exotic engine with a gazillion intricate moving parts and tight tolerances..... or a turbocharged engine.... or under extreme conditions like racing.... or if the vehicle was subject to extreme temperatures. Or if the manufacturer recommended synthetic. But for most of us under most conditions, with run-of-the-mill engines, I'd stick with dino. Regular oil changes are of course important with any oil.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
That's pretty much my thought too... Just wandering what everyone else thought. Thanks alot
![]() Join Date: Dec 2009
Synthetic has a more consistent shape molecule vs traditional petroleum hydro carbons. The main function of oil is to clean yes it lubricates but in that process it takes the junk to the pan then through the filter protecting the engine.
My though is use a quality oil, filter and change it every 3,000 miles Just my opinion. Posted via Mobile Device
West My Project and Photo Album http://67-72chevytrucks.com/vboard/s...d.php?t=378159 http://67-72chevytrucks.com/vboard/a...hp?albumid=641 |
#5 | |
Local Redneck Authority
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
#6 | |
God is good!
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 Last edited by TheWhiteElephant; 06-01-2011 at 12:09 PM. |
#7 | |
~Rest In Peace~
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
What about the lack of zddp?
20' Daredevil (Ret)
That's something I have never worried about, but a valid concern anyway... thanks for mentioning it.
Here's a good discussion: http://67-72chevytrucks.com/vboard/s...d.php?t=381780
Thanks alot everybody
here is the best read on motor oils i've read anywhere.
http://www.ferrarichat.com/forum/sho...d.php?t=136052 |
I use Walmart SUPERTECH SYNTHETIC just to extend life between changes. not for moneys sense but for laziness. I do Run ROYAL PURPLE in my Harley but look at the the difference. Harleys are not water cooled and need extra help in cooling
2004 Silverado Crewcab (Dark Spiral Gray) |
Well i know on my dads 78 silverado k20 that he bought new he switched over to mobil 1 at around the 5,000 mile from old bone oil and proceeded to put 500,000 miles on that truck .
we pulled the top side off to put a set of fuelie heads and an rv cam in it at 500,000 and it still had origional cross hatch in cylinder walls. last i heard that truck had another 300,000 miles on it. Its been through several clutches,front end has been rebuilt a couple times,several midas lifetime dual exhuast systems ![]() theres a synthetic oil testimonial for ya! ![]() |
one down fall of the synthetic oil though is if you have a pin hole any place in a gasket it will find it!
#15 |
It's Better With Nitro
Oil is oil. The application can make a difference particularly when it comes to practicing extended oil drain intervals. If you don't plan on practicing extended drain intervals, or if the OE doesn't specify a type, I would purchase according to price and availability.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#16 |
I have always ran straight 30 wt, plus a qt of the Lucas oil stabilizer every 2500-3000 miles. Never hade any probs in the 20 plus yrs of driving 67-72s!!!
#17 | |
~Rest In Peace~
#18 | |
hes always been religous about keeping oil changed and keeping things cleaned up top/bottem you could eat off the motor and even the axles on that truck if you were so inclined. |
